207 -
7
Posts posted by max
hi i just put a rivet in mine
i think i might have some in my shed will look at weekend if so you can have them if can get to kinks lynn
18 minutes ago, MarkBzero said:
That will be a fun job. They will need a rolling road session to set perfectly to maximize power and fuel efficiency.
shhh don't tell the wife just see the look on her face now ---- you and your toys
i had a good Christmas the postman has done a very good job bought my new bike carbs and the inlet manifold kit that i have to weld up and fit, just off to get carbs ultrasonic cleaned and new 1.7 main jets fitted, cant wait to get started tinkering again
could you not use your roll bar as some single seater's do
30 minutes ago, richyb66 said:
Just need the jump leads and the Easy Start.
project for the new garage richy ?
17 hours ago, richyb66 said:
Engine is crossflow so not a Metro. Servo on LHS on a RHD car (looking at the rack) and shape of the rear pillar suggests it's a Fiesta and probably a MK1 (think MK2 onwards were cvh not ohv).
Worth £2k if it's got a V5!
you are right ,the exhaust front pipe is mk1 fiesta fitted many when i was younger
56 minutes ago, marlin said:
No worries, just curious? Health issues first and foremost.
HAPPY HOLIDAYS TO ALL! AND STAY SAFE
and the same to you,lets hope next year is a better one
when fitting bike carbs have you just vented the engine to air or set up a breather system ?
20 hours ago, Peter Bell said:
If you have a Mk 2 then any of the monocoque models should fit, 1,2,3, exmo .
thank you
when fitting bike carbs can you connect to one of the inlet tubes so as to keep std breather set up ?
11 hours ago, nelmo said:
No, all different...
thank you
hi can anyone tell me are all the roofs the same on all models eg size and fitment please
On 11/28/2020 at 12:32 PM, Andi said:
Bike carbs are the way forward. Kawasaki ZX6 (may be the cheapest), Kawasazki ZX9, Yamaha R1 (can be pricey). But there are many others that will work too. Youll be best off with a simple cheap bike carb fuel pump (most will do). There are weird and wonderful ways of tapping into the carb runners and making plenums so that your brake servo works but TBH a 2B doesnt need one. Just a heavier foot.
You will need the manifolds that are custom made by the likes of Dan ST and Bogg Bros but you`ll probably find a full set of them and carbs complete for sale on here or ebay.
The performance will increase dramatically.
is there any makes not to buy ? or are the 3 that you mention the only ones to buy ?
6 hours ago, Peter Bell said:
How much work has been done on your engine? If you just want it to give a better initial kick then using a 38dgas will give that effect as both chokes open at once, it will fit on the same manifold you have. Ultimate power will be very little difference as the dgas has 27mm chokes and the dgav 26 and 27.
std but lighten flywheel i dont won't to burn the rubber of the tyres just a lot better pick up
52 minutes ago, RedTrev said:
This is worth a read if you haven’t already done so:
hi thanks,think that's the way forward for me as the cost of 45s would be too much
Valve guides - Pinto.
in Engine
you could use a additive in your petrol as i do
