130 -
Posts posted by Greenie
if they are the same as on the 2b, the rears will need the reflector edges touched up with a file to pass
These are the same lights that pased the SVA at the time it was built.
Greenie
I have a pair of rear light clusters & front indicators that came off my 2B Plus, these are free to a good home.
Greenie
Hi Greenie I have one if you want it. I am at j8 m61 Chorley
Dave
Hi Dave, sorry not been in touch work has taken me away from my PC, if you PM me with your details to arrange a time.
Thanks Greenie
I've an untouched stainless dash panel from a 2B kit that is just getting in my way. It's free to anyone that can make use of it. I don't want to post it so collection only- I'm just North of Wigan, near J27 on M6. Brian
Hi Brian,
If you get no takers for his I'll have it, I work in Westhoughton, so collection is easy, put me on the list if no one else wants it.
Greenie
Use a 1.7mm main needle jet, and lift the needles up by 1 notch in the sliding choke assembly.
Thanks Lads....any idea where I can get these?
Greenie
At I am running R1 bike carbs on a 1.8 Zetec, I am a little disalusioned as to the performance due to the jets, would I not be better with a pair if 40's or 45's?
Greenie
On my quest to purchase a state of the art shift light, I have ended up with one to many, so hence this opportunity for someone to own an adjustable shift light.............£30 incl P & P if anyone is interested.(cost me more)
I will be at Stoneleigh tomorrow.
Greenie
Hi I was interested in your snap off OMP Kubic.Was it expensive? and being non tech would it fit my steering column assuming mine is from a sierra (as is the engine)
Ta
Pat Brant
I bought the Snap-off from Ebay for £63 (bargain they range from £90 upwards), the Kubic steering wheel, along with the boos I bought direct from YB Racing (OMP Agent), they are quite expensive, the boss was £43 and he wheel itself was £109 (both incuding postage).
The only problem I came across was that the Snap-off did not fit the boss, I had to have the boss
re-drilled to take the mechansim, works and looks a treat, really finishes the car off, plus it is easier to handle, I found the Mountney a little to small and round for my liking.
I will post some pictures, when I find out how to port them from my new mobile phone to my PC.
Greenie
I have just swapped my Steering Wheel for a OMP Kubic incorporating a Snap-off quick release mechanism, hence I have surplus to requirements a Mountney Wheel & Boss. £35
Collection only I'm afraid
Greenie
always use blue hylomar on mine and it never leaks
Hylomar is the best solution for Pinto rocker gaskets, but don't over do it and let it go tackie before fitting the rocker to the head and tighten evenly.
Always make sure that the surfaces are clean and free of oil, wipe them down with a small amount of adhesive/solvent remover, this dry's instantly, works a treat.
Good luck!
Greenie
Every cork gasket i get seems to be collander based and leaks.
Where can i get hold of a rubber coker cover gasket?
What type of engine are you looking at futting a rubber gasket to?
Greenie
Is there anything here that would help? or at least start you off.
dont worry that the maps do not say bike carb, the maps for webbers will be OK as a start for bike carbs, they have four chokes so do the wbbers.
Thanks for the link...................They are deffinately a starting point.
Greenie
Have a look here at the Omex website
Thanks for that, I will be contacting OMEX this week.
Greenie
Looking for a nice sporty shift light to sit on the top of my dash, looked on EBAY, but most come with a REV Counter, which I don't need. Don't mind making one if anyone has any ideas?
Greenie
still for sale but have no pic unless you can wait till next weekend
OK
Greenie
as salty says £50
Has this been sold?. If not have you more pics?
Greenie
Sorry to hear about this Keith.
In my experience for this one to get as far as Court there would need to be an independent witness. Was there?
To pull out from a junction onto a main carriageway into the path of a vehicle (even if indicating left) can amount to Careless Driving.
To approach a nearside junction whilst indicating without the intention of actually turning left is clearly misleading and can also amount to Careless Driving.
Only independent testimony will clarify who essentially was in the wrong, and only then would a prosecution follow. Insurance companies will argue knock for knock and unless you can categorically say (or prove) that you were not indicating then the companies will probably go 50/50 or thereabouts. Sorry.
As long as you can prove that you were already postioned and active on the carriageway before the T/P pulled out of the side road you should have no issues as far as blame is concerned, I have dealt with many of these in the past within my line of work. The T/P party should not have presumed that you were turning until you actually made a manouvre, she should have made sure of your intentions before she made her move.
Good Luck
Greenie
price reduced, needs to go, I start my new job Monday!!!
Go on then how much is it now?
Greenie
I am looking to purchase a D shaped steering wheel with a quick release boss fo my 2b Plus, I have tried various models but can't seem to find the correct one, can anyone help?
Greenie
Hi Pete,
try this guy
dmhcomposites@hotmail.co.uk
came recommended by Mark in Blackpool, hes in Blackpool too, i think hes exTVR
HTH
Mitch
Thanks everyone I'll give them a whirl.
Greenie
Zeemerides
in For sale
Hi I am running on rear Sierra Springs with uprated shocks, how hard are they to swap, I am at Newark on Sunday but very interested in these.
Greenie
