Hi Guys
Went for my rolling road to get the engine set up to run right and pass emmissions for IVA on the 16th Sept, BUT...... did not really get too far.
Main problems are that the sump is still leaking like a sive and lost about 0.25 of a pint in oil. The other big issue was that the rubbers holding the ZX6R carbs on are too short and the clamps were not getting a good enough hold. Suprising as this was all supplied by GBS with the manifold!!
This was causing some good air leaks so not really able to get much done on the set up, but after a few runs found that the fuel pump was not man enough for the job. I used the ZX7 fuel pump but on tick over was about 2.5 PSI but when at about 5k revs was 1 PSI.
So jobs i need to sort are silicone rubbers to bolt carbs down better, bigger fuel pump and regulator and stop the sump leaking (alreadty got this planned, thanks Gaz ).
If anyone else has had these problems or knows a good way to fix any of them, please let me know.
On the plus side at about 5k on the rollers at about 3/4 throttle is sounds awesome and it did not blow up so alls good really.
Steve
