richard mackay
Everything posted by richard mackay
  1. Cheers guys thanks for the advice I'm crap when comes to electrics
  2. The sender I got from kit spares has only one threaded pole or rod on the top of the sender with one wire on the inside. I connected the power and sender signal wire to the pole and the third wire to earth. When the ignition is switched on the gauge goes up to full. When the the ignition is switched off the gauge goes down to half and stays there. Whether it's a coincidence or not that the tank is half full I Don't know. Electrics are not my strong point guys
  3. No to be honest
  4. Just fitted a reconditioned sierra sender unit and when I switched on the ignition on the gauge went straight to full even though the tank isn't???
  5. Cheers gents
  6. What set up have you chaps got for a choke for cold starting with bike carbs
  7. richard mackay
    Fuel
    What are your thoughts on the E10 fuel thats coming
  8. Cheers bud
  9. For the last while I have been doing a Zetec upgrade it was a crated motor so no engine number I've sold the pinto so what do I do about engine ID.
  10. Morning folks, anybody on here got indicator/hazard warning stalk for a 1986 1.6 sierra? It was my Donald car years ago. The hazard switch will no work any more there is power there but that's all. Cheers Richard
  11. My Sierra was a 1986 1.6L it had 13' steels. I fitted 14' bk racing alloys that were on a MK4 Escort. When I went for what was the SVA in 2004 I was worried a about the Speedo reading slow but I needn't have worried. Now I'm fancying a classic sort of look and minilite style wheels do the job for me.
  12. Cool, no issues with offsets etc.
  13. Has anyone on here ever fitted minilite or superlite wheels on a Sierra base car and what size etc
  14. Cheers for that
  15. What is the latest on engine Swaps or upgrades for older cars having new or newer engines fitted?
  16. Cheers will look into that. Richard
  17. The engine runs sweet once it's clears after about 5 mins but it's like it's going on three cylinders and popping through the exhaust and back through the carbs. When it clears it's revs perfect just wonder if it's flooding a little while starting because it's takes a couple of attempts to fire. Richard
  18. Why does my zetec black top on bike carbs take so long to run clear from cold. Even when it can run without the choke it's like it's got an oiled up plug but does clear eventually but too long I'd say Richard
  19. Cheers Gents, I ran the engine for quite while with the the needle well up and when I stopped the engine there was no sign over heating what so ever. Complete silence. Cheers Richard
  20. I have just finished fitting a 2.0 zetec black top in my 2 series. My car has the Sierra dash cluster from when i built it. When the engine is running the tempreature needle is sitting much higher than when the pinto 2.0 did. Does the zetec run at a higher temperature or have I got a cooling problem. Cheers Richard
  21. Can anyone tell me why I can't slide the choke mechanism back and fore. I think it's stuck in the off position Cheers Richard
  22. Fitted regulator and it seems to have cured the problem Richard
  23. Anybody have any experience in firing a crated zetec up for the first time Cheers Richard
  24. Going to order a regulator the same as what Maccavvy has and see if that cures the problem. Can't do nothing till next weekend as I work away from home. I'll let you guys know how it goes though Richard
  25. May have narrowed it down a bit. I took the tee piece of to leave the two pipes and switch on the ignition. The fuel came out of the pipe between the carbs that feed the numbers 3&4. Number 4 carb was full of fuel sitting against the butterfly so could that carb be the problem? Richard
