R.h. Series 3 Breaking For Parts
Guest Jim Robinson
Guest Jim Robinson
ALL BELOW FROM AN RH SERIES 3A (revised list following a good selling day at Stonieiegh)
See current postings.
Dash board, excellent black dash and instrument housing, ford
instrument panel Will slip over RH/Locost Or other Seven type
scuttle/old dash £35
Wings. Pair, Swept + Bracket to suit RH/Locost or other Seven
Look-alike (Good for painting, minor star cracking to gel coat only) £35
Guest nightracer35
Bonnet. RH, top vented with additional (4) marine side vents 2 x five louvre plus 2 x three louvre. £85
Wet Weather Gear comprising hood with one piece frame and side screens complete with strong s.s. piano hinges with loose pins, paired to Perspex side wind deflector hinges, facilitating quick change over from side screen to wind deflectors. £195
Tonneau (made to fit RH Series 3 and fit over high back Recaro style seats. Half split to allow driving with passer seat and boot area covered. £55 SOLD SOLD SOLD
Mountney Steering Wheel With Unique Centre-piece, includes steering wheel boss £40
Indicator/Lights and Horn/Wiper/Washer Switch and Hazard Light Switch Set and cover (Ford Escort/Fiesta) £20
Scuttle, RH series 3, fitted with excellent black dash and instrument housing, ford instrument panel £85
Indicator Lights. Pair, Front, Mini Style £10
Carburettor 2 litre (Special, built an ex Bert Holding of Preston carburettor mechanic/tuner, superb carburettor.) includes 2 litre manifold, all manifold mounted linkage/linkage support and accelerator cable. £70
Front Wheel Hubs. Sierra, Pair, fitted with XR4 Callipers and Discs (Vented) £60
Roll Bar With Fixed Stays. 1040mm wide overall, 395mm from stay fixing holes to front of roll bar up-rights, stays 660mm centres. £25
Petrol Tank. RH S.S. fitted with Ford Sierra sender and filler pipe work. £40
Wings. Pair, Swept (Good for painting, minor star cracking to gel coat) £50
Wings. Pair, One Piece Rear (Good for painting, minor cracking to gel coat) £50
Wings above Complete with RH supplied lights set (RH supplied rubber back wedge type) £80
Lights. Pair, Rear set (RH Supplied Rubber Wedge Back Type) if not sold with wings above £35
Full Sierra Suspension Unit with Ford differential, wheel hubs, brakes and RH supplied shocks. £80
Four Speed Gear Box £30
Prop-shaft, RH to match above four speed g/box. £20
RH Four in to One Exhaust Manifold £30
RH Silencer/Exhaust. RH original with polished s.s silencer box / S.S. pipe. £30
Custom Chrome Exhaust £30
S.S. Locking Fuel Cap (2 Keys) £5
Wing Mirrors. Pair. £20
Rear view mirror. Good, Quality Chrome On Brass. £15
1600 Sierra Engine with shortened sump recent overhaul with re-bore, new pistons and valve seals includes Alternator, Distributor, £80
Many other engine bay bits and pieces also available ring to ask what's available/what you need.
Delivery of any parts by post or parcel service at cost. Alternatively, parts can be collected or I will deliver to shows.
Telephone Jim Robinson on 01254 887274
hi, jim do you have a windscreen for sale? also im after a set of front mudgaurd brackets (for a 3/3a) if you have either can you please reply.
many thanks. ron
Guest Jim Robinson
Matt
Just found you enquiry below the Ad on my page.
I've never scrolled any further down that the send or submit button
Not too good with the web site yet obviously.
I can only apologise for not seeing it sooner
Jim
How much for postage, too far to drive :)
Guest Jim Robinson
Got the photos of dash scuttle and bonnet but they're 1.4MB each in Jpg format and don't seem to be able to load these on the reply form.
if you send me your e-mail address I'll send these by my normal e-mailer tomorrow.
Jim
Can you post or email a photo of the bonnet and scuttle please.
Guest Jim Robinson
Hi
The wheel is 11 inches in diameter.
Jim
Could you please tell me the dia. of the wheel?
