GambolGold
Everything posted by GambolGold
  1. Ah, no. I won be able to go to that one -but thanks for pointing that out.
  2. Sounds good. Sorry I have prior commitments too.
  3. More photos from 'Engine Vein Mine'...
  4. My reply does not appear here - anyway. I'll be there at Alderly Edge tomorrow too.
  5. Yes, at least me at Charity Farm on Sunday.
  6. Back off holiday. Plans to drive to Alderley Edge?
  7. GambolGold
    Radiator
    Okay. Thanks.
  8. GambolGold
    Radiator
    Hi, Do you still have this to sell, after almost a year?
  9. Wanted: folding hoops to hold roof. Its for an S7 Mk3 but could be standard Robin Hood.
  10. Thanks for the very comprehensive diagrams. I have the larger / outer hoop. I can see the smaller one fits inside, which had not occurred to me.
  11. Hi, My car has always had one folding hoop and the roof has been supported by the roll bar, but I've bought a new roof and due to it's shape I think it now needs two hoops as described above. I'm considering having a duplicate made which would then hinge off the first hoop. Any comments or things I should consider? Can anyone send me any photos of their set-up please? Regards.
  12. Indeed, here's to Stoneleigh 2023.
  13. I going down on Monday from Manchester, avoiding motorways.
  14. Thanks Peter, I shall.
  15. This look interesting as I live in Tameside. I'll have to see how quickly I can replace the front dampers.
  16. Hi, I've just received new dampers from Dave at Dampertech, Rotherham. the problem is the bolts on the car are 9.4mm and the damper bushes take 12mm. Can anyone say whether these the wrong dampers or is there something else I need to do please to fit them?
  17. I usually take a shopping list of parts, trim etc - loads there.
  18. Wow, glad to be back. It's been too long.
  19. Correct Longboarder. Thanks for the replies. I shall make a video /audio recording and check for induction leaks.
  20. Dip the clutch or coast, the sound goes down.
  21. It used to be an occasional quirk but now, once the engine is up to temperature and the car is moving and the engine under some load, there seems to be a whistling sound from somewhere. It is at a constant pitch irrespective of road or engine speed. It stops when I slow down. Does anyone have any idea what could be causing this. I though it could be radiator cap but I changed this - no change to the sound. Thanks for reading.
  22. I've had a few over the years. What destroys mine is high winds and gusts. The movement wears the water proofing and soon after weakens the fabric. I've invested in a cargo net 'thing' which I hope will stop the crazy fluttering that happens when the wind picks up.
  23. The coning tower is the important bit. Imagine how useful that would be when you visit a circuit for a race meeting! a decent periscope should be fitted.
  24. Fixing unreliable ignition key barrel - with what ..... to be continued
