L/w Rear Shock Mount
Guest JNS
Guest DoLittle52
Rats, this front suspension problem is more aggravating than I had imagined. O'reilly's was kind enough to allow me to search their shelves, but coming up with a drag link/tie rod end that fits the supplied A arm and the Pinto upright/spindle is eluding me. The female threads in the A arm are 18 mm which restricts the drag link/tie rod end population.
The taper in the Pinto spindle is different from the tapers generally found on non-domestic vehicles.
So I spent my money on the spindles and now it seems that I will have to scource the Sierra/Merkur spindles and then the ball joint and drag links we have identified.
  • Replies 227
HI CHUCK,
I WILL TRY AND HELP. THE UPPER BALL JOINT CAME WITH MY KIT, THE ONLY MARKS ON IT ARE (AKAL) IF THAT MEANS ANYTHING TO OUR FRIENDS ACROSS THE POND, OTHER THEN THAT I CAN'T HELP YOU WITH THAT PART.
AS FAR AS THE STEERING TIE ROD END GOES YOU COULD GET TIE ROD ENDS THAT FIT THE PINTO SPINDLE THEN HAVE A THREADED TUBE WELDED TO YOUR STEERING RACK ON BOTH ENDS, HAVE THE TUBE THREADED TO THE TIE ROD THREADS. YOU COULD ALSO USE A ROD END AND A ADJUSTABLE TIE ROD ADAPTOR STUD (SPEEDWAY PART NUMBER(916-36055) IN PLACE OF PINTO TIE ROD END. I WILL TRY AND FIND THE PART NUMBER FOR MY TIE ROD END THAT I USED WITH A SCHIM. WOULD A PINTO RACK AND PINION WORK?
GOOD LUCK
JOE
Guest DoLittle52
Because I did not anticipate this problem I had the A arms powder coated, cutting and welding on them will require additional powder coating.
I used crazedlist/Craig's List last night to locate several Merkur's that are being parted. I expect that I will end up buying the Merkur uprights and the ball joints that have been identified here.
I have Triumph tie rod ends that I think will work with the rack and pinion I have.
Guest ScotMac
Chuck, you didn't get a steering rack w/ the kit, either? The one i got from RH is actually pretty good. It is a bit slow (3.5 turns lock to lock), but i matches up w/ the suspension geometry VERY well, and has exactly the right threads for the merkur/sierra tie rod ends (though i used a rose joints). It is actually a rear steering arm based rack for RHD, that is perfect for LHD and front steering arm based when you turn it around (it mounts on the bottom of the steering rack mount plate rh supplies). I have a thread on here where i detail exactly what car it is from and the part no. Let me know if you want me to look it up.
-Scot :)
Guest ScotMac
Chuck, yours must be from Coveland, since that is right up their alley. Mine (and Joe's) are from RH. I have no idea how well the triumph will work, but i know the Fiesta one from RH works well.
Joe, i have no idea how the 310 differs from the 311. Maybe threads? or splines?
Edited by ScotMac
Guest DoLittle52
Yesterday I started riveting and bonding. The 3M 5200 adhesive take 7 days to bond so I have plenty of time if I screw up.
The air rivet gun from Harbor Freight works great, takes three pulls put it puts in a tight rivet.
Today I am going to buy an air powered drill and an an abrasive cut off tool.
Joe, since you used the Pinto spindles what lower ball joint did you use? Did the ball joint come with the kit?
Guest ScotMac
HI CHUCK,
I got my lower ball joint with the kit, but it looks like the one that Scot posted on (61). You will have to make a shim for it.
Joe
Chuck, congrats on starting on the chassis. Hope it is going well. Now that i have mine on four wheels again, i am doing the pedal box (floor mount) and running the brake lines. I don't know much about flaring, but i am learning. It appears that Stainless-Steel-Brake-Co wants me to do a double flare w/ stainless tubing for all the connections on the line-kit i bought from them. It is interesting to do double flares on stainless. Had to get a fairly heavy duty flare tool, and it still is just putting out "ok" flares.
Yes, Joe used the L/W standard lower balljoint (and i am pretty sure it is the one that Nigel found and that i posted a link to). It will work perfectly for connecting up w/ the bones, but (as Joe mentioned) will require some kind of customization to fit the taper in the pinto upright/spindle.
Hey Joe, how much more to do? Any photos??
Cheers, -Scot :D
Guest DoLittle52
ScotMac got a body shop catalog today that has a hydraulic flare tool, if you are interested I will look up the details.
I received an R1 Yamaha motorcycle shock and it looks good although I don't have any idea what the spring rate is. It springs and shocks the rear end of a Yamaha so logic seems to tell me that it would be a relatively light spring. (around 100 pounds). It was cheap so I will try it and if necessary I will chuck the spring up on a mandrel and shave off some metal.
Guest DoLittle52
1989 MERKUR XR4TI 2.3L L4 F/I - All
1988 FORD THUNDERBIRD 2.3L L4 F/I - All
1988 MERKUR XR4TI 2.3L L4 F/I - All
1987 FORD THUNDERBIRD 2.3L L4 F/I - All
1987 MERKUR XR4TI 2.3L L4 F/I - All
1986 FORD MUSTANG 2.3L L4 F/I - All
1986 FORD THUNDERBIRD 2.3L L4 F/I - All
1986 MERCURY COUGAR 2.3L L4 F/I - All
1986 MERKUR XR4TI 2.3L L4 F/I - All
1985 FORD MUSTANG 2.3L L4 F/I - All
1985 FORD THUNDERBIRD 2.3L L4 F/I - All
1985 MERCURY COUGAR 2.3L L4 F/I - All
1985 MERKUR XR4TI 2.3L L4 F/I - All
1984 FORD MUSTANG 2.3L L4 F/I - All
1984 FORD THUNDERBIRD 2.3L L4 F/I - All
1984 MERCURY CAPRI 2.3L L4 F/I - All
1984 MERCURY COUGAR 2.3L L4 F/I - All
1983 FORD MUSTANG 2.3L L4 F/I - All
1983 FORD THUNDERBIRD 2.3L L4 F/I - All
1983 MERCURY CAPRI 2.3L L4 F/I - All
1983 MERCURY COUGAR 2.3L L4 F/I - Turbo
Guest ScotMac
Yes, let me know on the flare tool. I have finally made *one* good one (out of 4). I think i have the procedure down, but i am worried that i will to bends based on that one, and then get to the other end and screw up the final one...hence wasting that entire length!!
The criteria is that it works on Stainless. Most are just for copper, aluminum and mild steel.
What is the open and closed length of the shock? Is it adjustable? Are you thinking of using it for the front or the back? I assume front. We don't have much margin for error in the front, in terms of travel distance. I have double adjustable QA1's, which are VERY expensive. I got the QA1 DDR3955B for $500/pair. I believe Summit NOW has them for $600/pair. They are 12.625" extended and 9.5" collapsed.
-Scot :)
