Gearbox - Close Ratio Or Not?
Guest paul091085
I have a spare type 9 gearbox that came with my robin hood when i bought it and was told by the previous owner that it was a close ratio box out of an old mk II escort rally car. I am not to familiar with gerboxes, so how can i tell if its close ratio or normal? I need to sell it but don't want somone buying it and finding out ive got it wrong.
Any help would be appreciated
Paul
You need to determine the ratio of each gear so select each in turn and turn the input shaft until the output has completed a complete revolution. This will be in the order of:
1st 3.65:1
2nd 1.97:1
3rd 1.37:1
4th 1.00:1
5th 0.82:1
For the standard Sierra box, the V6 box had a higher 1st (about 2.6:1). On a close ratio box 1st will be around 2.6:1 and 2nd and 3rd will be different but 4th will always be 1:1 with 5th as an overdrive.
Look on the BGH Gearbox website (cant get to it from work at the mo!) they have a list of the ratios in their c/r boxes.
Im presently 750 miles into running in the new XE & the BGH close ratio box.
Both are performing very well
(eventually....dont ask... full story & pictures will be available at Barkstone!)
Bob....not mr Grumpy any more... :D
Is it a 4 speed or a 5 speed?
If it a rally box then the only way to tell the ratios is to take of the top cover and count gear teeth.
The V6 box has a 3.36 to 1 first with a 1.81.to 1 second.
If you have a rally close ratio box, personally i would keep it.
Even with the longer 3.3 V6 box 1st is still to short, idealy a gearbox that gives you 45 in first 65 in second and 85 in third would be ideal
Guest paul091085
Thanks for the replies fomr everyone. Its a 5 speed, but I have been busy with work so have not had just to go look at it yet. I will get up my lock up at the weekend and have a look at it and find out what it is. I was thinking about fitting it in my hood, but the thought of taking the engine and gearbox out again just isn't very appealing at the moment. I was told it needs a new input shaft bearing and that is why it was taken out of my hood before i bought it. Ill post my findings at the weekend
