In my op it's a no brainer only a comp strip gives any better results and then only marginally regards mower man :good: :crazy: :clapping:
Guest scrabster
hi,i used a similar cone when i did mine but it has a nut and bolt in the narrow end to hold it in a vice.you do need a bit of muscle to get them on though.dont do what i did and put one on the wrong way round :80: :D the cone cost more than the boot so if you havent bought one yet you can borrow mine if you get over this way at all.hth.
jess.
Guest MartinP
I also used these from Panda Tools.
Took a whole 15 minute to fit both ends of one drive shaft.
You will find it easier with an extra pair of hands or a good vice on a bench.
Martin
I bought a couple from panda tools but didn't need to fit in the end but will do next winter in planned strip down. Service was very good.
Guest pixie clarke
I have been looking at these, because i need to replace mine
But everywhere i look they suggest the medium boot for the Sierra
They say the size of the medium boots is
“Drive shafts from 20mm to 35mm diameter
And cv joints from 75mm to 100mm diameter”
The measurements on mine are 24mm Drive Shaft and 60mm CV Joints
So surely the small is best for me
Size of Small - 20mm to 28mm diameter and cv joints from 65mm to 90mm diameter
The only reason I’m asking is just in case I’m missing something :huh:
Guest MartinP
I used the recommended "Medium" they fit very well, my shafts are 24mm & 60mm over the existing boot.
Martin
I also used the recommended size fitted fine just trimmed the fat end down once on, i will use the on any car now .
stuff a strip down when these are this easy and good..
Guest pixie clarke
Thanks for the replies
I have just ordered the "Medium" ones :D
Paul
