Garage Clear Out
Guest AllanU
I am about to Move House and need to clear out my garage, and this is what I found I need to get rid of:
1. 1.6L Eco Pinto Engine, from B reg Sierra. (Free)
2. Weber Carb plus manifold for above (Original Carb fitted to 1.6L Eco Engine). (Free)
3. Weber 2V Carb plus manifold. (Was fitted as an upgrade replacement to the above Pinto.) (£15, or free if taking 1.6L engine too.)
4. 5sp Type 9 Gearbox (No Bell housing) (£10, or free if taking 1.6L engine)
5. Single Core Radiator, (was originally fitted to RH Exmo.) (£5)
6. Spal (VA10-AP9/C-25A)Electric Radiator fan as previously used with item 5 (Pull) (£5).
7. Spal Fan Mounting Kit (Many bracket options) (New) (£5)
8. Pacet Fan Mounting Kit CF300 (New) (£2)
9. Quick Fan Mounting Kit (New) (£1)
10. Thermo Viscous Fan. (From Sierra)(£3)
11. Sierra Engine Management Module and wiring (From B Reg 1.6L eco Sierra) (£5)
12. Front Anti Roll bar inc. Power Flex Poly Bushes (from Ford Sierra 1.6L)(£2)
13. S/Steel Pancake Air filter for 3 above (£2 or Free if taking Carb)
14. PiperCross Foam Air filter and Base for 3 above (Foam rotting, base and gasket good) (£2, or free if taking carb)
15. Ripspeed Carbon Shift Universal Gear Knob (New and boxed)(£1)
16. Pair Universal Concentric Top Mounts + Fittings (New) (£25)
17. Rear Camber Correction Plates for Sierra rear end (New)(£2)
18. Yellow Clutch Quadrant (£2)
19. Front compression struts/tie bar set for RH (To Replace Front Anti Roll Bar) (Free)
20. High Level 3rd Brake Light (Unused/New)(£3)
21. Vibra-Technics Gearbox Mount, and mounting plate, for Type 9 Gear box (New)(£10)
22. Vibra-Technics Engine Mounts (Pair)(New)(£15)
23. Power Flex Bush kit PFX PFPP-101 (New) (£2)
24. Mountney Steering Boss Adapter Kit KK040 X Ford (New) (£3)
25. Clarke Engine Stand (£10)
26. Yale Heavy Duty Chain Hoist (£5)
27. Pair of Rear Coil Overs inc springs from RH Exmo. (£5)
28. Bag of Blue Silicone Hoses Off Cuts and one Elbow (£2)
29. Folding Cup Holder (Screw fix to vertical Panel)(New) (£2)
30. Ford Sierra Heater Blower (Free)
Photos of all of the above Items are available for interested parties. Items For Collection Only.
Please email me at allan.usher@globalcrossing.com or call my mobile 07776331510, for more information. I am located in South Reading near Junction 11 of the M4. If any of the above are of interest please get in touch.
Note: Available Soon –Robin Hood Exmo, Stainless Steel/Green, B Reg, RHOCAR Award Winner, 2.1L Vulcan Tuned Pinto (135hp)and 5 Speed Type 9 Box, Soft Top, Alloys etc. Only 3000 miles since completed.
Thanks For You Interest,
Regards,
Allan.
hi alan have just got robin hood exm was wondering if you have any wiper linkages blades or motors currently car has sierra motor but linkages are a mess so am looking for bits or any help also any bits that i could use will you let me know what you have left and could probably do with some cheers andy Aberdeen
Soory no Wiper linkages or parts.
Cheers Allan.
I would be interested in the gearbox please, when does it have to be shifted by?
Hi its yours, as soon as possible, please but a couple weeks time is fine. If you need more time let me know and I will see what I can do.
Cheers,
Allan.
Guest john wilkins
