I have just bought a GBS zero kit and have started putting the panels on before i fit the center tunnel section, i want to pre drill all the holes for brake lines and fuel lines. could anybody tell me if there is any IVA regulation about distances they have to apart, i was going to do them at 10cm but thought i better check first as if this is wrong and it fails it would be a pig to get to.
any help would be apriciated.
neil
Guest oddsocks
neil
Hiya neil and welcome to the fun house. the spacing for the brake lines are max 300mm apart so do them closer to be on the safe side. Become a member and you can upload you pics of your build-just noticed you have! Put your location as well, might be someone close to you building.
You only want to put drivers side panel on at the mo, you'll need access to it later on in the build.
HTH
Jamie
Guest gixerboy600
Hi Neil,
Welcome along!!!!
Take your time and look at a few others build pics before getting stuck in!! Yanto, Shaft, Mine and Dinger's are a good place to start, if in doubt speak to GBS (Richard or Keith) are invaluable!!
As Jamie said put your location up as you could be just up the road from any of us and we can help in exchange for tea and biccies.
John
HTH
Jamie
Hi Jamie,
That was quick, thanks very much for your help.
back off to the garage for some drilling fun.
i will put some photos on soon.
Hi Neil,
Welcome along!!!!
John
Hi John,
i was just actually looking at your photos looks very impessive.
i have just added my location thanks both for your tips
Kettles on if you fancy a long trip to Reading!!!
Neil
You are IN the villiage where TVS hold their monthly meet; give Chris N a P.M.to find out next meet. :rolleyes:
will do thanks
Guest Spencer Griffiths
Hi Neil
Welcome to the world of kit cars. Have a look at my build pictures as well, Im in Harold Wood by jnc 29 of M25 if you are ever passing this way.
Spencer
