Hydraulic Clutch Mt75
Hi guys is it possible to have a hydraulic clutch fitted to a MT75 box ive got a pedal box that can be used for a cable clutch or a hydraulic one. basically when I bought the pedal box the company sent me everything to make the pedal box hydraulic as well. how easy can it be done or is it a major job.
Andy
There are a number of companies that will do a hydraulic clutch conversion kit.
Rally Design, Burton Performance, Demon Tweeks.
Generaly 2 solutions.
1 an internal one that replaces the clutch leaver and fits over the input shaft.
2. A hydraulic ram that acts on the clutch leaver, sometimes outside the bell housing, sometimes inside.
I have seen a system that uses a very small cable or rod connected to a lever on the chassis that is acted on by a hydraulic cylinder.
Edited by Snapperpaul
graham coles (GDC) has fitted one on his car dont know if it is mt75 box or type 9 though. I is just a small pull type cylinder
