Prop Let Go At 90 !
Guest NantLladron
Guest NantLladron
The prop let go on Sunday whilst going for a blast , certainly focusess your attention , are the propshafts on a s7 custom made or donor sourced? does anyone know?
Guest NantLladron
Thanks Carl , yes luckily it let go at the diff end so nothing to dig in the ground just a few dints in the tunnel and ripped the brake lines out , will get it over the pit at the weekend and have a proper look
can you post up some pics? i think we'd all be interested to know what bit failed. I do metallurgical failure analysis as a day job so i'm even more interested!
Guest NantLladron
Yes i will post some pictures at the weekend ,from initial view it looks like the rear UJ thats gone as half is still bolted to the diff but not sure whats left of the prop
Guest AdrianH
Is it a 2 inch tube or bigger prop shaft and what is the engine and expected BHP?
I know that one can just have a fatigue failure of course, but wondering on the rating of the prop and parts. Reason is I was asked what my engine was and it's power before I was supplied up to 150 bhp and I got the standard 2 inch as you see on sierra, over that the prop was approx 3 inch diameter and a lot heavier UJ's.
Glad no personal damage done, apart from perhaps a change in attire!
Adrian
Guest carl leonard
There's no substitute for getting proper prop shaft made by a specialist supplier which is up to the job. Considering a lot of kit cars start of with 'mild' BHP and then get modified after IVA (more speed), its worth the investment from the start.
My four pence worth
carl.
My four pence worth
carl.
Agree totally. I've still added some strength around the tunnel around the UJ's, and made crude angle deflectors away from fuel line at UJ's as well. Although I know my prop is a good one (for those that don't know I have Carl's old 2B), I still have worries about the fuel lines down the tunnel though and what would happen if a failure occurred (this isn't just about my car must be the same for may). With injection pump, inevitably failed fuel line, resultant high fuel flow rate and lots of sparks from prop bits = fireball. Must re prioritise the job list to re route fuel lines away from tunnel.............
Guest NantLladron
well guys got home to get the car up in the air and have a proper look .........ouch ! back UJ has broke , prop has flailed around took out the wiring loom , brake lines , handbrake cable & fuel lines..........the many comment above luck and concerns about all these things running down the tunnel are very true .......
in the pictures you can see how the handbrake cables have kept the prob up ....prop itself looks ok
Looks like that U/J has never seen grease since the day it was put together.
I would have thought that it must have been making strange noises for a while.
