Setting Up Pinto Dizzy After Engine Swap
Guest hanksy
Hi can some one help I'm going to change my 1.6 engine to 2lt tommorrow and wanted to know what to do about the dizzy do I use my old one from 1.6 or use the one rom 2.0 and do I just put the dizzy in and tighten bolt or does it need setting up Iv never changed engine before but up for the challenge
I would use the 2.0L dizzy on the 2.0L engine
Weights are slightly different
Make sure engine is on compression stroke ( both valves closed) No.1 cylinder
Rotor arm should point to No.1 spark plug lead in the cap
Edited by Snapperpaul
  • 4 weeks later...
Hi, Having a similar problem. Fitted new head and timing belt removed. Now don't know how to get the pulley lined up on the timing drive. Any one know?
Piston 1 at TDC
Both inlet and exhaust valve closed on cylinder 1
Then set as diagram
Turn I've gently using a spanner on crank bolt to check clearance
Re set as diagram
Cam rotates at half crank speed so takes two crank rotations to get cam back to correct position
Set distributor as diagram
Fire up
Use strobe to check ignition
Adjust distributor so strobe reads 8 to 12 degrees on the crankshaft auxilary pully
This diagram show the relationship with the engine timing marks and the TDC pointer
Turning the distributor will change the point the spark fires and therefore the strobe flash illuminating the pointer and the cut mark for the desired idle ignition timing
Some tippex or white pair helps
better explanation needed...as long as the cam and crank are properly aligned the pulley for the dizzy doesn't matter.what does matter is that at tdc the dizzy point at no1.
you can remove the dizzy spinb it to the correct place then drop it back in.
