Diff From an Escort Mk2
biksz
It will be etched on the crown wheel as per the pic.
If you can't find the numbers then count the teeth on the pinion and the crown wheel and divide one into the other.
If Lotus likely to be 3.95 or potentially and very very rare a 4.44 IIRC
I once ran a 5.3 in my MK1 twink and it was mental off the line but flat out at around 80!! Nice on the twisties and tight forests but no good at all any where else.
Escort diff and cortina diff were in different axles
Although I think the baby atlas was escort width
There is a lot of checking to do if you want to sell with lotus credentials otherwise its an escort live axel diff
The "English" axle had the same diff arrangement in both the MK1 & MK2 escort and the MK1 & MK2 Cortina through the whole range.
http://i213.photobucket.com/albums/cc169/ZV2527/DSCF5681Small.jpghttp://i213.photobucket.com/albums/cc169/ZV2527/DSCF5656Small.jpg
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRL8MNNOXf-OdDTjASGODeRkoXUxmdQ_CUB_JPT64qGCYUcE5BfsA
Ford lost the plot when they went European and started building the crown wheel and pinion into the axle casing,.MK3 and above Cortina's used this as did the Capri range, instead of having the nice simple bolt in diff.
http://3.bp.blogspot.com/-SnF7quWII2U/T1zKzWF6cmI/AAAAAAAANoY/zilRr9OwUDk/s1600/Boll0602.jpg
that's the same shape I got just goto find the ratio tomoz I have had it for twenty year never fitted it just put it at back of dads garage and forgot about it but did get told it had been recondition when I got it with a old mexico engine I put in mk2 escort oooh old memorys and lots and lots of fun. :crazy:
If you are unable to decipher the ratio from the numbers then count the teeth on the pinion and the crown wheel and divide one into the other. He presto one ratio.
HTHs
found the ratio its a 3.89 the crown wheel is 35 teeth the pinion is 9 teeth thanks for advice all ian I found a website that works the ratio for you lazy I no but it works lol
