biksz
Everything posted by biksz
  1. Well drove to meet heard a rattle thought cam was rattly. Engine cut out as got in carpark of pub would not start so left it for a bit.came to.it when time to go started fine had oil pressure just a little rattle then set if home lol drove at 40mph all the way home as the rattle was like marbles in a tin can but still had oil pressure so thought it was cam due to having oil pressure.changed cam started it up and no the rattle was still there so pulled engine out and took sump.off and no 4 big end has gone oops.so need a crank regrind and a check of a old crank I found from a 2litre which looks good but will jo when get it checked and then get some shells and refit and hope is all ok
      • 1
      • Like
  2. biksz
    Stoneleigh
    Well was planning on going in the kit but I have done a big end before all the stick starts it has lasted three year of my driving lol so not too bad realy lol but hopefully should be done if not 90 percent chance of me bringing car and caravan lol comfy sleeping for me
  3. biksz
    Stoneleigh
    will be going this one again hope weather is a bit warmer though lol
  4. biksz
    Pinto Problem
    that was just a little 10 minute job it threw a rocker so put it back on you cant do that with a zetec lol
  5. biksz
    Pinto Problem
    Tractor my pinto still runs spot on lol ask Jaimo lol no issues with mine and it was from scrap yard for 80 quid all I did on it was new oil pump and had head done to unleaded and a few tweaks which I won't say lol
  6. I made the hole bigger where the exhaust goes through the side
  7. Will.still.stay in the club I can't justify the car sat in garage doing nothing in the last 2 month I am lucky if I have done 50 mile
  8. Robin hood s7 registered 1994 runs a 2l pinto 4 speed box and 3.92 diff.i am selling as it don't get used apart 2 or 3 times a year for shows does need some tlc as needs scuttle painting. Has got a full Cage fitted looking for £3800o.n.o
  9. I'm away till Friday
  10. Brill weekend yet again the good laughs and banter as usual and everyone chipping in with everything again and helping each other as a club should.brill second family bring on the next one
  11. Could do but got 2 mot's in the morning to do so long as they pass yeah lol
  12. Me and my daughter again
  13. No buns just burgers
  14. Picked up burgers there is 30 a box and they are 6oz ones lol
  15. Will do Keith might be more than 34 burgers won't no till pick em up
  16. Getting burgers this Friday 4oz ones about 34 of them
  17. I should be able to get burgers will find out this week
  18. biksz
    Steering Rack Stops
    All I did was drill and tap and put a bolt in the rack for the steering stop then the rubber gaiter covers it up
  19. I emailed the dvla a while ago now asking if I could change the mono chassis to a gbs chassis without an Iva I asked if it was OK to reshell my s7 and they said I would need a Iva as the chassis is different I would 0f considered it as I don't plan on selling my s7 but as said if in an accident and so on then everything is void as it's not mono chassis but tubular chassis hth
  20. biksz
    Acuspark
    I did not earth the body of the coil
  21. biksz
    Acuspark
    Will put it down to coil then as ran seperate live to live side of coil and black to earth side and still got no spark
  22. biksz
    Acuspark
    So which of the wires from the dizzy go to the coil?
  23. biksz
    Acuspark
    That was with the accuspark dizzy the red wire.went to the ignition side of coil and the black wire to.the earth side but still no spark can't understand why though so put old edis back on to check and the old dizzy has a spring bouncing about in there so got another dizzy that runs of the edis and fired up straight away but still would.like to.no.how.to wire accuspark up as want to get rid of edis to eliminate. I ate problems later on
  24. biksz
    Acuspark
    Getting 12volts each side of coil with ignition on and both sides drop when crank but no spark
  25. biksz
    Acuspark
    No nothing still doing my head in now
