S7 Mk1 Rear Coil Over Design Brackets
biksz
has any one got any designs on how to fit the coil overs to the rear.i have got for time being the original rear coil overs which are zimmer I think? just wanting to no best way to fit them as they have a bolt hole at the bottom and abar with thread on at the top will get pics tomoz if it will help.
Pretty standard set up for the S3
Yes the shock bracket on the lower arm will cope
The angle iron is 3mm thick and bolted to the sides and the rear extension of the side box section
I also bolted through the roll bar and put load spreading washers on the inside of the rear tub
