Gearbox / Engine Swap Help This Weekend, South Yorks
Grim
Tractor called it correctly, valve stem seal loose. head rebuilt thanks to rob and terry, still lots to do it tomorrow
Shame we couldn't quite finish the build in 1 day....at least we got the head rebuilt, valves re-seated and new seals all around. And a nice "CLEAN" and shiny block/ head....I will be inspecting it for leaks and chips on the next meet... :rofl: :rofl:
Cleanest part of the whole car now :crazy:
Hopefully you can get it completed and back in today mate :db:
managed to get bottom end sorted out, crank and aux shaft seals, sump swapped over. Big & main bearings checked, all ok. Flywheel bolts were stretched so swapped for my spares along with flywheel. Gearbox and bottom end fitted.
Bus to work tomorrow, will pick up new head bolts etc on my way home, and attempt to finish mon/weds evening.
Thanks all for the help
