At Last
tractor
Now here's an off the wall thought about the zetec. You say the engines been played with. Haven't got the cams swapped over by any chance? Worth checking. The inlet has the nobs for the cam sensor at the flywheel end. Exhaust doesn't. While you check you can also check cam timing.
don't know where you got the engine has been played with it hasn't the megajolt dosent use the camshaft sensor it is redundant just crank sensor as said the only thing that's not been changed is the edis plug so thats the next task
