January 7, 201511 yr Hi All, I'm in the process of installing Megajolt to my Pinto engine which is running on cbr900 bike carbs. I would like to have a second temperature sensor so that the Megajolt can adjust the timing relative to the temperature of the engine. I am aware that I cannot use the temperature sensor in the head for the MJ as well as the temp gauge so I need a second one. I have a temp sensor in the top pipe already for my temp controlled fan. Does anyone have any other ideas where I could put another one? Having read this forum (http://www.locostbuilders.co.uk/forum/3/viewthread.php?tid=63708) it appears I could put one in the coolant drain bore (3/8 NPT thread). Has anyone else done this? Thanks all!
