Zetec Instead Of Pinto
Guest Monty2556
Guest Monty2556
I've got a RH with a Pinto engine. I'd like to update it for a 2.0 Zetec. However
1. The Zetec is never going to fit the Pinto engine mounts. Can I get engine mount adaptors.
2. The Pinto has twin 45 Webers which I'd like to fit to the Zetec. Is this possible. I know they'd need re-jetting.
3. How do I go about setting up the ignition system without the need to get involved with ECUs etc.
4. I presume the sump will need changing. Where can I get the design for a new one to be made up.
5. Anything else I need to know.
Many thanks
Guest lotusPaul
An over looked point..you don't actually need a different sump..I have the standard one and it's fine..If you do swap it don't get a big winged one..zetec engines run less oil at a higher temperature. Otherwise the carbs may need more progression holes, or just sell what you have and buy new.
