How easy is it to fit a TPS to a pair of Weber dcoe carbs? Can you change the direction that the accelerator cables connect to the carbs?
Very easy save time and money and buy the right bracket. I moved from twin dellortos on xflow to webers on ST170 and had to change the accelerator mounts and cable direction, with no problems. Can upload photo later if it would be beneficial.
Thanks for the info. If you could put a photo up it would help. It's something that I'm considering as a winter mod, the bike carbs I'm running at the moment give good economy and power but I've got a misfire at about 4200revs if I floor the accelerator. If I press it steadily and let the engine catch up then it misfires at about 5200. It reminds me of the old SU carbs when the dash pots are empty of oil. Marg says if I drove normally then it wouldn't happen!
