Pinto engine
Guest George Laing
Hi
i have a 2B with pinto engine fitted.
engine doesn’t sit level ,front end sitting  lower.
any advice on whether it should sit level.?
You probably won't get a Pinto to sit level in a 2B and still keep the carb under the bonnet. The all seem to sit down a bit at the front, ideally the carb mounting face on the manifold should be level but I wouldn't worry about it too much.
