September 8, 20206 yr Hi guys, Just a quick question. I have just fitted electronic ignition and want to check my timing. On a 2ltr Pinto what is the timing normally set to before TDC? TIA Ray
September 9, 20206 yr Author 11 hours ago, theduck said: normally 8-10 degrees at idle and 30-36 degrees at full advance. All done, sounding and running much better now, thank you 🙂
