GBS Zero Pinto to Duratec conversion
Thrashed
 Share
For the clutch, you could use a master with a very small integral reservoir. It looks like there is space down there?
Something like this?
12.4.2020
Today was planned to be a day off.  A few messages with Stu (The Duck), and he convinced me to get off the sofa!  Todays job was basic setting on the ECU.  This would allow us to check the engine will still start after all the wiring and ECU resets.  This was a good hour session, which proved the engine would start and run.  It will need some tweaking as it is rough, but i need to finish the coolant system in order to do this.  Hearing the engine run is always a great motivation, so a spot of lunch and next job was the windscreen!  I have been avoiding this as it feels like a big job.
I have read Dan’s (Brumster) on RHOCaR and Richards blog (https://richards-gbs-zero.blogspot.com/2013/06/windscreen-prep.html).  Both give very good guides on what to do and how to do it.
I was lucky enough to `steal’ Dan’s windscreen glass template.  He has a couple of screens
made and drew an outline onto cardboard.  Stage 1, cut out the template to shape.
akQRClNRUX1wrzFj4BawafsP2dBSohu_IjLjvfXjMxzWmd07eliYoIMmzZJE2Vm6qRZqjiRXEbILmycMnbiIEEA5XCr6SVm3Xkvm2xYbB1bFuo-idp3KskejUJzCBCDCaLGkNvNB
Dan was even good enough to give me the requirements for the glass type and markings.
Step 2 was to make a full size replica.  The screen thickness is 6mm so a sheet of MDF, a marker pen and a jigsaw, created this.
rlh6nV7-Ap5Vj_Dfu04Enx1Aa9AX6oum1JjAdaIYrV4Tdk6VY_XHZuhgu1BAA83jk-K7dTA1fElhJkXNkTl4JNoh9ZHXhXt_q7Cp7Rnub_4mV4JwOjylgKuEyk6mEG_njlUoP_Rj
Being sensible, this is likely to be a template I keep for future windscreen replacement, or if someone else needs a template, so i copied the specs onto the MDF.
Step 3 was to try and make the top rail fit the curve of the screen.  This was easy enough and I added a couple of alignment marks for reference when it comes to final assembly.
UesOgq6TusDNZ3JS931RkvmAphYljWg5IPycv0AvTPOz7qiMcQtP4KaPyHpo-B9DjN3W7RvEdGqelDL-13eb_grCqWwFVfmBIdab6qBMNmEt-Qy3IijO9DULJvg3ftjIFvi3eNZV  p-EVT0uWrDvzUWfpsLiM4wAp4UDZLENTSaYWjmIiQUAltbmVrMRDwhmESpwFPvyckEMXT7Gb3H6hbqvwBK3XaFrju6GthVHyMcvh2xCBT3FamnhFhHtTKU-f_qi7V-V7linE-18V
wrNsj5kwp0djSxZW0swH9Q0JeiFvKd5qlR4W_nZ6B1na8sVsR56O5roUhikQk97anLe1WSQFFyAGTfvM_ce9EVynoBWnwfHwvNSs8qdTRT_1UGgf7IMwi60FNE2Dn1GKrqdHN0-q
The basic shape was easy enough to form as the main surround is already pre-bent.
UZ7n_bn2m3uBKBbxvi3l6_rD0zTcj2t7I7b7ZOi51WizYR9iuf3fmyGhms0Hpf-6EXOvndS-uj3SUAS8OGFa34PhgZMy80RmbNmou4T4n1iJpqtEV82e_3qkPgpUsBW1_2cT_pCp
I used the racket strap to keep the tension on the frame sides
I offered up the bottom rail, but this is going to take some more research as these are several versions of the same theme when it comes to cutting and securing the corners.
The most common version is to drill at an angle and screw to secure the side to the bottom.  Richards blog shows using a plate to add a bit of strength and i have been given the idea from Gaz (Midlands RHOCaR member) to use a 90’ plate.  All seem like a good idea and will give the fixings something extra to bit into.
So, whilst i research the method i will adopt, i couldn't help but trial fit it to see what it looks like on the car.
At first i just could not fathom out why the screen looked so wrong!  Must have sniffed too many fumes for the tuning tests earlier in the day!!
PmwXOtDaMy8VMPQh4aBv_rN5lo_ZaOBooSau17KK3AwF64IV5I1rp3HgW5ALWilyYFx3cFGDnmp2fefMuWdcUKzaxvlSoXmLCCVOUJxJQbF-r4AhTELfp5ue9SpSLABvGPyJX02j
After figuring it out, got the screen on the right way and it doesnt look too bad.
zRVM4wDjzQkGZrfkJFm9iU4nUOnXz2BonKoh21bKM77dH_Hg2e7cg_p1hiPL6vYCjvtLmFj088W-QTUtppxRskHz_2rz--dJcuJl8Gx2gDpd84w7VaXgQA3nRMvYxr022QjHEJ5l
The rake of the screen looks good when the bottom of the support bracket is horizontal.
The previous holes for the aeroscreen, should be covered and hidden by the screen, so this will decide the fore and aft position on the screen.
Final positioning will be left until I have the wipers and demisters, so i can make sure everything fits.
Next thing was to check the height actually fits me.
I needed to check sight lines would work for me and that my head is actually behind the screen when I sat in the driver's seat.  I also need to check that i would have enough height for when the surrey top is made.
This would also give me a chance to check the pedal box now it is in its final position.
YrQiU_qtG7-JkzrLuTc-YNcDUQUThGHq57HbiH-jlY1Zl8Wr_or2CoPlPjDQJvXBMBbUpt4vOpijWM5e1xQLdj1Yx-JdjuKCtvahEAipOc1qOPQJGV42dbP9yp1MZ7pqi_9IX_Lo
jCjEkZTgQiyJM0-m7AWOcUYpgq2nSjQdxLa7DJtRB5mhnBNW84zILkbkEOv1VpL0ekofD95Q5hITkU6kxe_EMRVRPD8FcA32cLevsGFdyzKmmqKdnPrhrlXMCuPf-okuFzzTU9kd
You can see above my head a piece of back conduit.  This is sat as a straight line from the top of the roll bar to the top of the screen, which will be slightly higher yet, once the screen frame is on.  This gives me plenty of headroom, which when I get a surrey top on, will mean it shouldn't feel too claustrophobic.  Also it means i will be behind the screen and out of the wind blast.
Think i will do a parts needed list and get ordering.  I need to get onto ordering the wipers and demisters.  I also need some adapters for the master cylinders to hoses.  I am sure, once I start looking, I will have loads of bits that I need.  With the lockdown as it is, I just hope I can get the parts delivered.
I have enough bits to be getting on with in the meantime.  I will shape the screen supports, finish the plumbing, finish tidying the wiring and more.  Lets see what i can get done during lockdown.
26-4-2020
This weekend i was working on the coolant system to get it finished.  Main job is checking the plumbing routes and fitting the expansion bottle.
The original Fiesta coolant system has a heater in the system.  My car will not have this so needed to find the correct way to plumb the engine without the heater in the system.
This is how Ford plumbs the system:
cV5H1laJr4StzcDge4QaRvzHE0uwzFF2W_B64ukD57uerBbO4Z1yfTUVm0afK8FW8ffrVVe_UY_geqBz0z0duZHHq7EeagHPYKbIC2pO87h1o5aRtBhTiq8ck6JgBJofkUBnaxTG
To me this just looked like a jumble of hoses!  I also had the added issue that very few of the hoses fit, now the engine is in a rear wheel drive configuration and my radiator is in a different orientation.
I needed to find a way to plumb this but still make it work!
A bit of internet digging and research i came across a good diagram on the Locost builders site.
70ovv-9pmPiV4frPZdfEn6i56-lx-JH2gC5Dt5lSNwOA5LH2UaSML_SauvSUy-YiHy2w-zOCpm46hJF4-v7FwddkHD0h0u__57EcyC3sboqozqyjX55aa9iOE5KUMAZjTHVLmiKS
This was useful as it showed the water flow path to make sure i had mine plumbed up right.
The only issue is that it does not show the coolant path for the water to oil cooler.  This was a mixed blessing as i wasnt 100% on using it and the space for running hoses was very limited because of a chassis rail.  Speaking with a few kit owners, running Duratec’s for track days, seem to agree that on the road, the oil cooler is not a major requirement, but much more useful on track days.  The 2 main reasons given have been that the water to oil cooler helps to warm the oil quicker as well as keeping the temps down on track.  As mine is a 99% road car, not having the cooler was an easy option to leave out.  This is easy enough to review if i have issues when on the road.
With this plumbing now sorted the next decision was the placement of the coolant expansion tank.  Originally i had planned to mount this on the firewall, but i really wanted to keep this area clear for a clean look.
Finally i decided on mounting it just in behind the radiator in the engine bay.
In this location i can make sure it is the highest point in the coolant system, but the added bonus is that the tank will be hidden under the nose cone.  This keeps everything nice and tidy.
This location then presented a further issue which was i had nothing to mount it too!  The location i want would be in fresh air, so mounts are needed.
The tank only had two mountings moulded into it.  One is a strap what would allow a 3mm thick piece to slide in and the other is an ovalled M6 hole.
Having limited imagination and when using 2mm bent aluminium the tank was very wobbly and this was before it is filled with fluid.
ipF75dMwll_Zp4eL-qZg2YYTrdFsfBJUDmI1vqACsPhIOXHnb-YDsUGu2aJCcX03jIt79At_PDsGkw4Xowa82CWAQhir5n_agOESSqRFCvpbP_OFdbIWihj2oJRzFkMG8i79x2Al
X9g3Mu9YieraWfQmW6sdPvzggb3WLQOa496synk12qCOixs89ypoUHM87jI2UKblmdyT-4S_2XRPpCzqeUVIr7laSoToDNw_oAVIhvuohvizhBzK0oYlEFpXoKGD4ZIFb0zNKpkg
Thankfully Richy B came to the rescue again with a much beefier design.  At first glance, it looks like overkill, but Richy always knows best, so i followed the plan.
0ZHK4zwyf0bR3vOnFF9v5syDVfMLu1FFklLx0HhyjyvOsaNsa25H3_2IXepLMkJSOSBzpFDaiuzo8VZf9RQ01J059-XiaIpcfN-fmqwKFjwLQ9vZq3lc1gZee8zHkMNvss2FDmie
The weekend then involved 8 hours!! To get to the finished state.
g0J3ym8Y9FMNTPWj4XsCkCo1rPDa105FNKw5BMkWMB01YakrKq-DjTiSuJSKUB1DDX--atKjmLaykWTOKsh-FDHu_rAi3Ei5w-L_FN8XpetzrJkbpn-shb7wF7kVqxpHuutoyV76  ncBvvN8al00M1j79F5yl2hP4kvh2BrS4XD2bzLo9m12rNqcRxujNObZtCeb5d0XUFAbCZ2x0d2mXaJjxOXcX6UJbZcedNarYsTT8T1BCOGT5MJnoBH3UTkcQs6h0_r8UMKQXBUio
vHfhnUbUie5zo1prj_5m3MtBiW9u_T3sM65irDuNeojxh1B1exEMSfBgq5GrHnqBlcqWqVjxuwRupB44JRKLRGpFyR8MIsOxsjR0aZkHHlR2EwIOMcJAcBgXgK4MBCwsyZavszy0  _l3MTVZqPGeEnF084TZJ4xJbsGIfgTYdeakWpQgKLDd9ZDVRTb6921d0ZWlDeCZeZF8FIKVLlqhFqn3RblT_vWzjwDauK9CvKzkH8RMIGCyOReX0m9afHSqjUX8agg5L38Rr96Nz
M5JA_db5O0kX2LMfKLANhMeWB8pxniktncdeb78z-q5-ZJcTdOBwzcB4f3z0NB1bW-NJflmopidLszaSKNxFcDLhiTDl3n4qHkbs9UmffBb8ATJgC-VpzEZApAdmoeXkheuNlClK  3nHjjZnAEG4qADKMEc5rQk76v_WtGCd541uoPn4mocuC-TWNbEL2yNU948xhw2-Q6uv464dPPCGX36HQFEFyVdD3lBcju567UZ3pqY92LsxEaXYZ_wF35sGiUHxyeVCnZHT8fcs5
DgTHTs9LAJFB8VpCvXy2iJaX4IToBMzYUHGbgf6WiY54tprz29DCglYfsxrH093QyWbLx13hJH6L-aZoKCXNHfJyKpXrBTPk5lCShWUoX-vaMmjYVQXZzpRDSqggFQAb6u4SEP8d  f5j7e8rupwZdt0gy7XT1WKPeFFtxGXkqj5Jt9GfNk4OBlaiC4WycBK7MF1qdW0ftHspccf7DHvGO6eexy-GMTe_vGUKdOpZxfakY0N4yyA5UP78L_GFwAHogF4rCqzlnCP-Dra_2
yzu9Cyo6wGwrzY2CKiOvQwqv1pAnZpr2HS37O7QZMwFO_T8ZOOPVKzzl8j4zCn9fkYeTS9d90Eu7esK-gdhyMlFM2qX5VOZoBPI5W-uz77esS0pU0h0YZkQIo1PRavRgekFjT6iM  ttqPLplk1LL_CqLTceRFJ-e2jB1dbfXMtvrX8kQD-kgvtUQDxH6J3hMmmOdYzJxAGgaelhkxzz8s2CEv8mnLWTrmf1RXatzOHTyAjv3O0J3OKsJnsMTR3GhJ7taMQcf8UuTiQ7Rj
ShLfUraSmLfqs0apMhsf1K2e57Eyrmszq6HmqDy5TU7peVmwB1ixkItnFwFAiDqB6ef71biRJUR3ejUcUaK0QFNOI6Jy47EX0IsngaUBpJLl7pcOcD3kCBC57guWEaVZoQoprKEL  u-IqbfzMe48ifVTlvS87WkdVpqO51pDZHJYEVm55OKsQL9sEwvpQIW7TxyKYCazVkw7kY-eGUw_vsxpmlz04YbS4SSnYM0kFVi1RcTMyqrrAcrre2bRrAtNqlBbsfGMWIRIUEezn
kFesiN0aAUNmIxVqiD6iLwF9XIlVTrSyHE8DcPa8C_nTSs_vKlMjtq6WQmOvEd4-ssKQrPtOE1V7qRwb205cbFhK1870mRi80iZ1-iMXO-ojs6-XT4rE4-iLGwaes5v6gPzT_h-p Ab8FXWqhuujCVdke-tXK5msRuWyNn1ksQssTpx8eshg7I0YxjDn2hxKFcMdmsUyjpHcwYe6ugQODjB3LfGsWZqU5Mx7E9awZpaKDcwp1FMfiXuq9rGwKZemKPT_O9rkJdJ4CqO3U
f06n7CMu2WDInHGHIaQW3lMVkbkTJETyurU2ZlCEGNhL9c91NtvHCR3_cJBQd3yHPviGYqjiYXdfm0_RRbVUH80BOgajYteeXhmQ4NKq-OhSWVyxVFa5shOJyPLE0jWJZeGdWSDS  vgem3i21H_HUbngPkJYfY41A6WA_xVsk5DzosS8G9JmBM58WhHWGXZNr6pa7Gxak3YPvWBzSM4fblxCfJZeRsxGHnXKY-10I40YDIAgYfsEVj96UUa277QDM7-_2Juq25ggQZ37X
lx90qIlQ6-imfrfZNVTEqIMZNejOxlFZ7VN9szKzuaeTKPOGrTDkmRb_spc4voLBMJC8W7lL9Vxtaw1Cuwoytjx1PgTRLmV4beobwL8485grWrFqhPUdq_95CuCp1JvO4EAdmIs9  VMATIvEiSEK8BTNBB0zzNKs0hlqp2Tso9afWzbVy79fz7srInn-AyZKJz_Wmbrp3FHRq6juFIGtP9dKah4XYbsJHPaqSLDsD3EvWaj3yr4okmqp873VNh_fWb3b7tvbDPmsEeh9d
awNarlWkqZTAc-z72VUqqr-an20mxmZQLcAy2hIB1cxvTlzgqjDsBKy6jIapIDV0QYr0aZP1sSUD060TgAXha8n5ZQ54BJHUh3rJ6YK0jjyNtt1YN9hHDmeQxGfdqSL6rmhRn9CK
All in all, i am pleased with the outcome.  It still surprises me how long such a small job takes, but then Stu (The Duck) reminded me about Project Binky, and they have way more brackets than me!
 O1R8Jp-YcpE-OtXXBZzJvk0jnxWadWtR7EPur9Gv8MofOcgw6FekzTDLh8yYmyToBvlqh3aU9vL-7a3Hru3WJ0tzNah9A3-6VZGgJWDVUszbsp6siNl-UH2gLvdC6IppPNOG56KC  NfljH6nJBYpGAG7aVbLZ2U7BDG8Thazc3YIeLLwCUDcUCMsp1qHaZKQJyW4IAZouLwEpoN1Iw0wRu6wj5uCyhGu1VlVifiY_tNVEuQKSLLyXaozGmSuXU2kM4vXmcIx4lX8ZqrSD
kt4MD5j530i0VJGzM13BgMY-CQzTRN6k2Oc3oiYKXufnZnJMUQPgbNymjBB286RZgC11po8INAkZz6AjY085LPX_RQNHXsog4FAMEPOxrY5QqPYclhHByervouOXeawt9I_sQAX9
All that is left now on the coolant system is the small 8mm tube that runs from the manifold at the back of the engine by the bulkhead to the expansion tank at the front of the engine.
This is going to be done in one piece which will involve a few 90’ bends with short rubber hose connections at each end.
27-4-2020
Aluminium tube turned up today, so had a spare hour this evening to have a play.
jbJ9Ta_T8pntSWPvkbaZYcttju4ByJlk8kv7lM1yQiEzQFaz1iuKtrIQ69ZErTtZMb6ZLcnf1CW0RX8Oub2V1bEMcUmg3M27Lvo2YxqqULoJ4Zcj00-OcqFLA8JgaHk9cx7rr6i-  hAu1bfNwCrn27PXz9lppv5gBf_nIEq67B4ccUxTDu9J6tGlrOauQGUgaVW6HdXfT70uTHMyZz8yLP1sK1ZibeOiRR-BQIJUnHb7x6AF-oqustzQxLZCTCwkAQ07ZrKzG9GjGbzSA
I needed to turn this, a 1.5m length of 8mm OD tube into a tube that followed the engine from the water manifold at the back of the engine along the rocker cover above the exhaust manifold, around the front and then to the expansion tank.
When i bought the tube i made sure it was 6063T6, to make sure it would form easily.
I also have a mini tube bender that forms
6,8 & 10mm tubes. This is the first time using this and i had no idea how difficult this was going to be.  I decided buying 2 lengths of 1.5m tube was a good idea, one to practise on and then the final piece.
It turned out not to be as hard as i imagined it would be.  The tool has reference marks for where the bend starts and degrees all the way round to 180’.
It was just a case of measuring the length and getting to grips with the way the bends are formed but first go i ended up with exactly what i needed.
k9syNGRtYFjsgE6uE-makCIhUc9GngM2z7d9-D7M193gxllHI_6LonWFv15Q6asxcyPxHk-pJoX7WA6BxEFyDRso-TCTXe6GACL9kOEOCeLGOvWaCd7uImi1DEW9sDGEA8GO4Rmz  mnsddptN_BqJs5HqOnoMWaRtwlyTlfIrRJV4w_Yk2zz5vOCA8d3JBAUcodxIh1IGRMknMDyshtJhY_h7kRWTIvtuWelQKIIV2X5v3rzKvQshBW044vk-W0sPY6Vc4AryplYGw3OL  yeSaLueeN9CzhuLKM7F7hBHNjRFrbfO_W1kbpWEDNLbI0Oa8kYAkUePuLIPodvZwGfEaBzezM-qgBcDphWadUWcbESTWOgmi4amWQwck_kkutnUlk1O0RboZi42x4x0v92DQ0TJU
JATKaLG-FjFKCjtil-IUPha15uF8boTDkZuyTZHZhuRDM51ZiuhEyqrAFQuCEcJU0UtQkugUpgjxfkhfyf0VFCRbqL5YDvrBZFt3XsfLe9MPQehKQ2PuqpV_jo2Bj8AV_FMZgyHo
When placed on the engine it looks good even if say so myself.
j8e8wnqycH620Wsjs6XWJd15_D8XQbTjiwfCyURrXSIzxWGjtqhBovhfRZuCSm5O_SY-wZm86PITM_cY9mKIAstNnWPMGdF75WNjoqOlQPpXtK9QvTxKOPnrchfo1twxLSLbQQsF
smFGKoW7HOlpzWU-RkYPqr-R_Lh2YPLdCySFxEOm1kjBc8NOriiTH01-QaE6BBbI0qSp4mqukCwKfbBHDtGxrEKWFWOMyPjzAssSQyjlbsIIw5RXJ3odxF7Wct_9_PKT7L-AwCzI
KLLjeHr_v4oj43kxqcKgIpViII9pIt-GLjBW3dv3VmiLIxc6c8sJobDUUGL_uXIiH3V59jZYHj-FOWSliLyE1UaGQ8HnOTEqDvlNOLCb3wDzPlEsUPmjDCG7e_2TSjESYBERRnhR
rsxNj2dnxVnZRHne4Y6Lg0jeAqdid19UWN_iI30DjnUzwKey3c0SGN2b9E6GVbhFKCbKH74sV_Kpf_AT7vDBX-Qdq771H6se2bErz_VSdxArFWPJvPSdKi_yWPErbu2xjE3CMCdi
I just need to add a couple of rubber lined P clips to hold it all in place and some rubber hose to connect to the water manifold and expansion tank.
The final part of the plumbing will be the final connection from the thermostat housing to the bottom of the expansion tank.  All easy enough as it is just cutting a bit of 16mm tube and silicone hose to the correct lengths.
3.5.2020
A little progress this weekend.  The fittings for the brake and clutch lines arrive during the week.  This was a case of screwing them in and nipping them up.  All easy enough and the net result looked good.
gCDdcS8n2w4MXsrCxrp20eJbdiA61clu_fZeyyCLAN4-wDmm6DsFFOS27lg0I2BKq-q1rlD9dpv62YV4S9SCTik8-62ytRZxpONRFsEnSxqFxwmwf-3lsOtsr7n4EOwo1pedlFFI  8OH3CFPkYZB6RuVa2HwW4qsErQTrAMbPTbKN6LPRbcurdI345_z7eAOFsNKYQl8n__ycVJKOIzfsNUmnbNywJ180W_gVW8Xi8Y0V7XLHtuEQzu2U6LJr3KP-p_C-F-N-oCqld8B4
Next job was to add some fluids!
I started with the coolant system. The system took just over 7 litres.  I thought this sounded like a lot but when i checked the Haynes Book of Fairy Tales, it suggests that an MX5 system takes 7.5 litres.  The good news is that i have no leaks.  This is without the engine running, but still a good sign.
Next fluid was the clutch.  The gear stick turret needed filling with oil.  The HBFT suggests that this be filled with 300cc of gearbox oil.  The clutch reservoir was next to get filled.  I also did some research on the fluids.  It suggested the Dot 4 is able to deal with higher temperatures, but the Dot 3 is more resistant to moisture.  I used a Dot 4 fluid.  This was the suggested oil in the HBFT so it seems good enough.
With fluid in, the next job was to bleed the system.  I turned to the trusty Gunson Easibleed.  This has never let me down and has always made brake bleeding quick and easy.  That was except this time.  The caps that are supplied with the Easibleed are far too small for the Compbrake reservoirs (girling style) which are about 65mm.  The option was to but a cap big enough or a more modern version.  I decided to take the opportunity and upgrade to a pneumatic fluid bleeder.  This will connect to the air compressor and will pull the fluid through the system, removing the air as it goes.
In the meantime I went with a bit of pedal pushing.  This `highlighted’ the first connection that i had not done up tight enough.  It is amazing how such a small amount of brake fluid can travel.  5 minutes later, all cleaned up and ready to go again.  This bled much of the clutch, but will finish once the new bleeder arrives.
Not having enough Dot 4 to do the brakes, i have left this for next weekend when the new bleeder and Dot 4 arrive.
Next little tinker job was to sort the steering wheel buttons.  I have 2 buttons on the wheel.  The right hand switch is a momentary button, which will be used for launch control and the right hand is mostly likely to be used for a map switch function.  Probably a normal mode and sports mode with flames and pops!
The momentary button is from when I had the Omex launch control.  One of the pins on the back was broken.  This was probably from when I soldered the previous connections and the plastic became hot and brittle.
This time i will be using a different method.  I saw this on a youtube video and thought it would fit nicely for my application.  The pins on the back of the buttons are 2mm.  All the usual crimps are too big.  The method i saw was an econoseal pin.
This then fits in the slot in the middle of the pin on the back of the button.
The pin then folds over 180’ and is crimped on.
A bit of heat shrink and a rubber boot later and that is one side done.
uIXIqYIgYRCsTeW7VudarYjk5aYwWAk4B_63_SE4pOSWXbxXmRv669-1xJIYqAwfeIBpFynn0aHm4pYSfEt13kBNBdDJPgwFUkRwqhsZ9D39FfxE2V8hT6jS6xuOkERbKuPCpneU
3vuHLejCzAVNmsc1pYr-9C47LCPfb8sYW0X2k9ZsDp5V_M3QCwLb60Mp-1CholW00dQCBJjtOAJgRIGo9a4xw2Al_fFePaebHn3gkgU5Bz5L_e_H0Is7BiV_MPH0FcuVSKVX0yEf
I will probably hot glue inside the boot as a bit of weather protection as the securing nut for the button is only 2mm thick so not much for the boot to grip onto.
Just waiting for the other side to turn up and that will finish that job off.
18.5.2020
So a little milestone this weekend.  The bulk of the windscreen frame has been completed.
It wasn't that bad a process in the end, i was conscious i only get one go, so it had to be right.  Just a bit of time and thought on the best way to do it was all it took.
Below are a few pictures.  Trying to do it and documenting the job is not easy as you need 3 hands at the best of times.
First part was getting the side frame and lower rail clamped together.  I used an M4 bolt, drilled the hole at an appropriate angle and clamped it all together.
lvPbh3q9vkuFH3QoCCRXYuO5QFkCocIPoqwBV_LtJfJrGFHlOyuxWJQjapxZlAUQD1-yzlgwZooIsl08TBuY_1lj5GWo1v1l_n-l9uA7gdv5-AAdChZUt5h_BnDP7FrXL6J7i8oO  FDIqlEv9kB72K0dptT20ENC1Jbmxu6u8jjoYha4PbLKxIZV8eu05qmOK00zav2kzA7lJB9Bh2xqXHqBSnzqtIgyYBxrhal3p0U6oSNsD0U_65SosI1KKlBxxt4-Y01OVPm_CRN_z
02M8ZS_R3rXVagt64Q11XR12S4nyGlDtU8glb3j-bWrfiOt4SvWMaZ7shs6hNRVmyAiQy-U27HnMz92XGWfwoxsv5fdtiw6WXzVqwK-FOG-aluI-sJRVoOfaIea-nlFtBQrVAllM
zR3GTSbtN8MgXHVxzPNeYluaLoqJzH3B8XpwcAAeHrrsiEsXbL7fwvd1GVnOFqCLMWoEKt8uOA7la991S1VgOOME9k_pYVOcJOyhWoATHtUEL0p0efMxQ8wz4ELU15wik7c1rtvd
u5TerLMWVlvqOiiv-Nn4Z4uTDrSRDwX0Y0r3Yq70nuzow5xxUbjg0AN4kLr8EoGioUVIiRNPwXF3QI62D5atm2P9bwhuT7eDSg5lAs5R9DRSY4D-mX1L9XqMhcunMFVNrpaezqho  vDTcXwb7IkYMW80r2ubIdr535KxOgoqZtb2nVOHJb-xyPX4Rc8J8ROSdrpFOFuJQ4bSZ0zPHeMSxbDm-c5m8G2i6RTMVfvW3VB1ZWkHiyhdzNeAKEEjW315Ohos_rV5-e4iBRTFq
Nd0BcqcJX73uiefdz84lhOsSBNA52Gk01uq2JXEfmkAro4i4xTTr2rNmKKz0pkothFcmL0JF1nv0Qv2J28wxDBDzH0O4XEk5QNZoITNS7tpc-MTsbO68sZSFPtWU_9H0uXVP0wgZ  wGL3b8jwK5M-qh57VfRGYJyrjDwNpTHNC_p7GMz_twtCOWyCSdiMTtkX7qWp3lEhktDTYQrXN1EOh99Wblch94hw-QyTcQ68FExlk1-vMfsDpbbceIbtc1VfOnUXiXmauj4f4ULQ
GdPZBtYUJpYkdE2D9x_B3sXTI0CYpIouu3U5abzBlZnB9MLhiiGEa5dzc_yAfH53M-Y077yVRCZdhDSJFqzf18BH-iDqQFKqosFTM2A0IqqpE5qXCvdQiUerwNgbPKEzhaqdgeu7  1SF3ddbbNFDw-T1nVZWG0bgcqxwllU0_H1fLp0C9a-14UKQJNqJw_-1NhapOi9c5oc6UxZZf171k7YGdItcxWH9zlo5weV7V53pG7SUkpXkB9Nci5mch9moSKZ7WgCFkf0byjMbZ
2qeX9MMls7OHX9RKnBsmdWxvhStu2A_Y7GpaoqJ5I-WkDJ8SELBug_qtFu30pP6kPocnk4qG8kBzHFuNqEtGsaSH8ea5KMoNYVFHschuHRZK5oFjvl_ysY22VgKfBBVHt1_BkPBa  m6mSQxRCNEcq-FEZpQovqJYnoHEP5nCDtEgvn8AOY2zTWoKlmUZ8PSTj4g_6Q0zZhdfpzYcJ2wJxb0Cyx9bwbVsA3FjT6fSgb9oxUazswe-srFNUEBRiwoPSQmx3yy-Eaq8hKptN
This pulled everything nice and `tawght!.  I played around with which way to feed the bolt and settled on the head inside the lower rail.  This allowed me to countersink the side frame which with a ground down bolt keeps is very low profile to the side frame
KR4PRYsFVJAx0kkeWfyEknvAcca06eY5uPiPLnQ1WaZCHiiw5K5wNXuM9akmxHWFEYP1UNOhkinOZigDZi8iMxRpi2hn6savx8ZjtpvsFkg5X3po49L-JAeOBdzA3sPT0xRypS4U  VZAWzZSwg9ypghkKr170vaMWVquatuG7xh5SSp2_i-ojWS2uzuERLGibSWwCuZNOetUfEZDOZ_YkPvTyu2_lIIcjQ9z-fZIByqoaYLlzuCptCzjLyhgrIfrB0hXjQMgOQwH-gMT7
I was concerned about how much clamping force I could apply.  I wanted to make sure it had enough to hold the glass in place, which is why I went for the bolt, rather than a screw.  I was not happy a screw would have enough threads biting into the frame.
eMAE_W1GiSAVw8XJMN4FTG21MQANTTv8QFMHEGU5SauYQrYt7V0CwQ2nfdpLfzZysW2HHZgF-htBpNEh214BOHgZBR-V86HPoOb4cc7q_2Ihvjv3Jz6mqVzo7EyQs6HdBPma6ttD
My first attempt proved I chose well as I managed to bend a bolt tightening it up.
This was a double edge sword as it proved i had enough clamping force, but also that i didn’t need to use maximum effort to get the result i needed and wanted.
Next up was to be brave and fit the actual glass!!  I was very nervous and very careful, but it went like a dream.
Gm6o-gnlwrwVQl1iT8lJjsWmhLe-awM3SnDRXGQUDOXiR6dMMXh09Gf5ZS6O6tzKeLByPWVZEapzzSgfvEGjqWZkwDHQOCWkElx7NMzrISWJFueGzgy22yAG4PryWn6Kcc0IxSLZ
I am well happy with the result and fit, so next job was to fit the rubber into the channel and make sure it all lines up.
I also trimmed the ends of the side frame.  I decided to go with the curve of the lower rail.
h58K8wA8lDpm7qWIiK6ihJKzS7H6j1YT_z5NOrKNOpdf1b305YffrbYhWlZ0_n9AWd0GHCWTWaiALjuMstiOEqiieK1zXnKwNMYlHlgXNdBLhfo97NPqk10PMWFFZStJIuB7k-JE
A bit of lube on the glass and rubber and it all slid together nicely.  The next job will be to pull it all aparts again!  This will be to drill and tap/ helicoil the side frame for the side supports.  I am not brave, accurate or skilled enough to risk doing it with the glass still in, but felt like it needed to be complete so I can fit the car perfectly.
Once this part is complete I will be able to trim the rubber and cut down the bolts.  Then it will be onto the painting!
As a side to the windscreen I had a little delivery from Dan.  He was kind enough to mill an EGR blanking plate.  It is just a cover/ beautification plate, but man it looks good.  It fits a treat and really finishes the side of the engine.  It is a shame it is hidden away behind a fuel pipe and wiring as it deserves more of the limelight.
1W0LxSlt-hfoHCYfEiraE6epI7oA08Fxk8ouNgaDIRVfsKX3MH2p1XBZLBeg18oY6KgFq3qgTgpmNQ3-cxA5bZel4Ee6fd7W9ebVC4t5roNGZaCI7avjfRc-2_RvKvMwk0418yvt  KbhyPRFuWZSKFZhTI1UFHLFMOBZcqxGAQoQ6s2FIZ0UAhKfF6760902v3Qmoxi_jkMaA1ofWDjTX-CjQ9djYjUYhbbmiZwEXhrF6sO4yVRs5n87ewMo2E1eisVdrMFpbo5hUgqYo
j8G0-In88fHSlli42KoaGEnV1rv50AUo2sff6B5XWy7e78rESwDHUDVkdtVL_DzRRdigmC1yQYII2X6U1yzDMABHKzNBnFcKS6ktZqK1cLmgFzmVbv_eTw_qXN50G6PQCn21D9J2
26.07.2020
Been a while since the last update.  The last few months has mostly been faffing about to get the screen sitting perfectly.  This has involved the screen coming on and off about a million times!!
It turns out the reason it would not sit straight is that the car is not square!  To be more accurate it is the scuttle.  The measurable centre point is around 20mm from eyeball centre.  Weeks of measuring and trying did not work, so i decided to make it look right, rather than being measured right.  Just hope not one takes a tape measure to it!
After i figured this out, i then fitted the glass for the final time.  I left the rubber trim long at this stage.  This will help when it comes to painting.  I will be able to mask under the rubber, spray the frame and then cut back the rubber for a nice neat finish.
This is what it looks like now
h5dBBluGfFmtoHDx8grjVtz7-lYzAQVYQC4Dnhs3tNy2_o1PnZKaGG5G68rgq1pIffYWipOC7tNZ77E00pqXxGEB-mJNKyvjzUeEmZP-zr9jBAbW526imVxHN_NXwJ-KJMtXeZGd
Overall I am pleased with the result, but it has been a lot more work that I first thought it would be.
Next up is to fit the wiper.  First off I started with the wheel boxes.  It all sits reasonable well and sweeps as well as i would expect.  It's not perfect, but for the number of times it is likely to be used it will do.
0NpuuPxP5hqa7WpRjfHpEW9eKs_7NmxDGVnXoz3dJ-WW7cJMeIRodaJDTMqBAsUXnqXGGQSF917IDqt9oGTL601aiXz-yTlAs3lLJXO6KJDz4RMH7I-z1NN1SVwtS9baxzS-Cpqu
The next job will be to fit the wipe motor.  Luckily I have enough space to fit either side of the scuttle, but my preference is the passenger side.  The motor is reversible so once it is fitted it can be adjusted to ensure it pushes/ pulls the correct way.
October/ November 2020
Now, it has been an age since I even opened the garage door.  The good news is I got through the final exams and managed to pass them all first time.  The down side is that the exams, running the business and a very heavy workload meant the kit has not had a look in.
The work situation is not likely to slow down any time soon, so I started looking at other options.
Option 1 - sell the kit as a nearly finished project.
Option 2 - just mothball the kit work on it as and when I get spare time
Option 3 - find a 3rd party to finish the kit
A separate issue and solution has also arisen as we need more office space so one way or the other the kit need to be moved as the garage is getting converted to office space.  The good news is a local friend has a storage unit.  It is on a farm with 24/7 access and only a couple of miles down the road.  It is an old barn that was used to store potatoes.  So, the kit is off to the spud shed!
This means after loads of consideration I will keep the kit.  All of the other option for a weekend toy just don’t work for one reason or another, although getting back into bikes I very tempting!
This is when all the stars and planets aligned to answer my prayers.  As you will have seen, our very own Richy B has opened his own business for all things, kits, classic, American and cool!
As soon as I got wind of this I jumped onto the phone and discussions started to get to the top of the list.
Richy has some tidying and organising at the Unit so we have set a date for the kit to get moved over to him in Tamworth to get the kit finished!
I have given him a very poor scrap of paper with a to do list, but the main part was that Richy has complete licence to do what he sees fit to fix the issues I will have caused and finish the bits on the list. Anyone who knows Richy or has seen his 2B with a V8 will know his attention to detail and skill level so I know the kit will come back better than I could do myself or even imagine.
No timescale was set so this would allow Richy to run this as a project in the background whilst still working on other paying customer cars.
Stay tuned for the car being moved and Richy working his magic.
 Share
