Headlamp Removal on Cortina S7
flameredturbo
HI,
I'm planning to sell my S7 soon so spent the weekend checking it over to prepare it for sale. The chrome has fully gone on the headlamps. I had a quick look at how they are fitted, popped out the glass and cant see how i would unbolt the whole unit, they are fitted to a fully boxed in section, then on the way home i thought do you access the bolt through the indicator hole just under?
Any advice welcome, thanks in advance.
S7 builders will soon answer your question I am sure. In the meantime, on the Exmo where the lamp is into an almost box section, there is access from directly below. If you also have access from below the you can use a "basin wrench".
Test Footer
