I've tried a search but came up empty.
Can someone kindly point me to a thread advising exactly what parts to keep from the MX5?
I'm about t o get handy with the angle grinder and wondered if the alarm / immobiliser and ignition system wiring needs to come out intact to be fitted to the Zero?
Probably not a definitive list but these might help:
 Keep as much wiring and bits as you can, they might be useful. Are you using the Mazda fuel system and ECU, if you are you'll be needing the immobiliser.
Very many thanks for your reply - I'm using the original fuel system and ECU so your comment re the immobiliser is most welcome.
Will need to do more digging to see what others have done re fuse boxes and relays and which wires need to go / stay/ extend or shorten when refitting.
I'll scan to A3 and encapsulate  a copy of the wiring diagrams and wiring key which should give me a chance.
