Hi all.
I'm considering swapping my 1800 pinto for a zetec and was wondering of those that have done it what did you about the exhaust, did you have a complete new one made or modify the original?
Thanks I'll have a look at that. Being GBS I assume it's for the zero so will there be any tweaking to fit a robin hood or will it be relatively straightforward?
GBS took over the rights to Robin Hood and are still the best source of RH parts etc. Apart from a new hole in your bonnet on the other side, I think it should be a simple fit.
