More electric woes ! Wipers ☔️
LeicJim3a
Need some help getting to the end of my tether ! Washer jets were not working no power to pump. So created a simple ignition  feed to pump via push button switch on dash and created an earth for pump. Tried and works perfect. But now the wipers don’t work !!! They were working while I had the pump out and was sorting this but now dead completely. Are the 2 connected could something I’ve done be the cause or is this just plain bad luck ? I’ve checked all fuses all ok so now I’m left scratching my head ! Where do I go next to try and sort this ?
I'm afraid this is all electrics and almost every kit car is unique in that respect. You need to get a multimeter out and test the wiring from switch to motor, test the action of the switch with the multimeter etc. Sadly, there are rarely quick fixes when it comes to electrics....
