If you're looking to upgrade your kit car dashboard with a budget-friendly digital speedometer/tachometer, this guide is for you.
I recently installed a basic Chinese universal speedometer/tachometer, and while the instructions were less than helpful, I've managed to get it working perfectly. Here's how you can do it too.
Where to Buy
I purchased my dashboard from eBay for around £30. Similar models are available on AliExpress and other online marketplaces.
Issues and Solutions
1. Water Temperature Sensor
The manual specifies a 900-80 Ohm sensor (Cold-Hot), but this didn't work as expected. At ambient temperature (20°C), the dash showed 2 out of 5 bars, and at 85°C, it maxed out all bars.
Solution:
  • Use a resistor in series with the sensor to increase the resistance.
  • Calibrate by using the sensor that gives a maxed-out reading at operating temperature, then adjust with a resistor until the dash shows 3 out of 5 bars.
2. Fuel Sensor
The manual calls for a 0-90 Ohm sensor, which can be hard to find. Most available sensors are 0-190 Ohms, which won't work correctly.
Solution:
3. Speed Sensor
The kit includes a magnetic speed sensor but mounting it can be tricky.
Solution:
  • Use a Brantz Motorsport Speed Sensor, which connects to the gearbox speed cable and sends out 4 pulses per rotation to the dash. This allows you to calibrate the digital dash to match your original speedometer.
Installation Tips:
Water Temperature Sensor:
  • Install the sensor as per the manual.
  • Use a multimeter to measure the resistance at different temperatures.
  • Add a resistor in series to adjust the resistance until the dash displays correctly.
Fuel Sensor:
  • Ensure the sensor fits your tank.
  • Test the sensor before installation to confirm it works correctly with the dash.
Speed Sensor:
  • Attach the Brantz sensor to your gearbox speed cable.
  • Use a cordless drill to simulate speed and calibrate the digital dash to match your old speedometer.
Wiring Matrix:
Final Thoughts
After overcoming these issues, my new digital dashboard is fully operational and looks great. I hope this guide helps anyone else looking to upgrade their dashboard with a budget digital speedometer/tachometer.
Feel free to ask any questions or share your own experiences!
Edited by ThanasisPolitis
  • Like 2
Looking good & a very useful write up.
If it was my car I think I might have to go for a slightly larger steering wheel 🤣🤪
  • Haha 1
