2ltr Dohc
Mitch
Hi All
Has any one got a picture of the clutch release arm from a dohc gearbox (MT75).
without the release bearing in, too check if its the correct one, (large retangular hole with no lugs to locate the release bearing).
i have been told today that these can be used for the VX 16v conversion and if any one has a spare, can i beg, borrow or steal, (or pay if i must) to try it in Andy windows hood, before we start to rebuild his car.
Ps may need the locating peg too
Mitch
Mitch,
This may help....or not!!
Im going down the XE 16v route.
The part number I was told to get by Rally Design is 71BB7541GA
The clutch release arm fitted to my Pinto/Type 9 is 71BB7541KA.
The SBD website shows a clutch arm as you describe, so I suspect you are right.
My Ford dealer had no idea what it was fitted to, so I have lashed up a spare arm temporarliy. But I'm off to a scrappy now to see if I can find a DOHC clutch arm which may fit better than my cut&shut version.
WALDEN Engineering quote the same part no Clutch Arm
SBD picture is HERE then go to SITE MAP, then CLUTCH RELEASE MECHANISMS
Cheers, Bob
Hi Bob
Yep, thats the one (pic on SBD) release bearing can slide from side to side, but i was given the part numbers:-
Arm 6812643
Bearing 6164967
and pin F7031464.
could be the ford numbers?.
If you want prices for the Inlet,bellhousing, and even remachined ally sump, try,
A Frame Engineering in Barrowford Lancs
Cheapest i've found so far and really helpful,
Mitch
