I'm after a couple of parts for my exmo.
I need;
- Both anti-roll bar supports/fixings
- Bolts that connect the diff to the prop
- Handbrake cable and ancillaries
Anyone have these or know where i could get hold of them?
Many thanks,
Lew
Guest Battery Bill
Lew
A Ford Dealer will sell these bits
wont cost much even there :D
Guest Jim Poole
Hi Lew
I've got some spare fixings for the anti-role bar if you can't get them from Ford. I had to buy a box of 10 from the Ford dealer as they wouldn't send me them as singles and hence have some spare.
Jim
Guest Andy Rathbone
dont bother with second hand brake parts, just fit new ones for your own peice of mind. and its safer knowing that your entire brake system is new.
Thanks for the help guys,
I'll go into Ford at the wkend and inquire about prices, if it's too much then i might be giving you a call (Pete + Jim) although i'll probably spend as much on petrol getting there.
Lew
Lew handbrake cables are not expensive from motor factors, it will need modifying to fit, ie. the inner will need shortening. Where abouts in Bucks are you?
Peter
