Armrests, like Caterham/Westfield use. Not only hold the door in but also nice for your arms. See my blog below for details:
https://zerolifebuild.blogspot.com/2023/03/arms-outstretched.html
That should keep you busy over the winter - you do realise that you've now set a target for yourself that we'll be checking on next year !
Only joking, but I will be looking forward to seeing it when the sun re-appears
Steve
Paint engine, sort crank shaft seal leak, wrap manifold, clean all of engine bay, paint clean and tidy anything that does not look 100%
i am aiming for a top draw engine bay !
Hi Brian,
I always used to put the blue into my Pinto - I don't think the red stuff was around when the Pinto was new. I used to put about 50/50 coolant & water.
I would recommend you keep the battery regularly charged. My 2B was always in a garage but it was unheated and got pretty cold at times. I used to try and run mine up to normal temperature every 2 or 3 weeks and move it backwards and forwards a few yards - enough to stop the brakes sticking. I'd then do an oil change in Spring before I started using it again.
Hope this helps, Steve
