366 -
Posts posted by deano266
Good news. It was a faulty earth for the brakes and indicators. However there is no power going to the O/S for the tail light and the reg plate.
Looks like I'm having fun underneath the car
Will this still apply if the lights are led
My dad said when I was fiddling with the electrics down the centre console it briefly showed some life but then went. So that narrows it down to a million and one wires possibly or could still be the earth point
Where does the O/S rear cluster earth usually ?
Help!!!!
I had all the lights working yesterday and just gone to pull out today and the other half noticed I didn't have any O/S lights (brake, side and indicator). The other side does have power and all fuses are working and the indicator relay is working.
Any help would be greatly appreciated as I don't want PC Plod pulling me over
Help!!!!
does anyone know the dimensions of the temp sender for the rover t series
Why how bad is it. That little gizmo sounds good for the money aswell. They may well be selling at least 2 at stoneleigh haha
Do you think that the etb fuel gauge will work with it or not and also if not will I need to modify the fuel float hole diameter
Hi. Looking at buying some ETB gauges. How bright are they at night and has any one got any pics to help
Brilliant. Thank you very much
Hi guys does anyone know the ohms reading for the superspec standard fuel tank as the car isnt currently with me so I can't get to it to measure it. Thank you
Hi i am looking at replacing the IVA rocker switches for the black billet aluminium switches for the Hazard Lights, Fan, Dipped Beam and Main Beam.
Firstly, are the IVA rockers single or double pole. Secondly, how are they wired in as we bought the car with them preinstalled and need to know how to switch them over to the new switches.
Thank you
Hi guys I'm in the process of rebuilding my scuttle and was wondering what should the distance between the wiper spindles that stick through the panel. Also how far away should they be away from the window.
They are the lucas mini wiper motor set and spindles with mini wiper arms.
Is this going to be a summer event
Where is the best place to get either Smith's Telemetrix or something very similar and at a very good price I.e under 400 quid
Because that is too easy haha
Mystery solved.
After speaking to GBS, it turns out it is a piece that they manufactured themsleves
Is it worth trying to carefully recut the splines back into the shaft as most are still visible
Hi does anyone know what the lower steering shaft is out of as mine has become rather polished where the splines are and has subsequently wore out the Universal joint. Also what is the Universal joint from a swell
Thank you
Mine were done post iva and run them as the sidelights wired into the ignition and MOT man has always been happy and even stating it was a great idea.
Thanks guys. I'm going from the ford focus stalks to a mini wiper motor if that helps the matter
Hi guys.
Which wire from the ford focus wiper stalk is the auto park function
What fabric do people use for the Surrey roof or what is the best fabric for it
Superspec Oil
in Engine
Hi guys what oil do you use for the superspec as about to replace the oil. Also what model no for the filter is needed
