644 -
14
Posts posted by DeanRudkin
I think I’ve got some off my 2b somewhere if they will fit
I used the original master cylinder I’ll get some photos when I’m over at my car next or check out red seven automotive engineering on Facebook my cars on there it may have some useful pics
Ok so the servo won’t work there I got rid of it I don’t know if others have managed to make it work I ordered a pedal box from gbs and welded it in
Tractor fitted one to mine when we did the zetec change but we binned off the accelerator pedal and used the original ford one
Rain-x only really works at speed like motorway etc well that’s what I found anyway
At very worse case take your rad out take it to a metal fabricators and weld it up
Phil shelton has done it on his 2b
Depends where it’s bottoming out I used to get a lot on the front end the old plough but you could always raise your suspension
Mx5 mk1 tomb stone ones
2 minutes ago, fry61 said:
Is it possible to "touch up" the trick colour if it gets scratched?
Sadly not it would have to be a full respray of the pannel
It won’t be to everyone’s taste I know and your more than welcome to come and have a look hopefully it will be at eosb this year
Yeah you will need new engine mounts mine are a Diy kit you can buy and weld up your self you can use the same prop shaft if your going to use the type 9 gearbox
Mx5 mk1 tomb stone style fit really well
Mazda Mx5 ones fit I believe
Phil shelton is one
Wrap it keep the seam under the tube
Ok mate sweet I’m sure they will be similar to the 2B ones
Can you get some drawings done and I may be able to make you some
wanted cycle wing brackets
in Wanted
Yes sorry been stacked out with work there in my garage
