DeanRudkin
Everything posted by DeanRudkin
  1. What engine is it on?
  2. Great show again weather held out same time next year?
  3. Check where your swirl pot sometimes it can get fuel evaporation is and also check your crank sensor make sure that’s not damaged
  4. I know the guy with the wild mor body mould if this helps
  5. Just get the car back drop me a message and I’ll pop by and take a look I know the guys at Parker’s In wigston well and they always managed to find the pinto parts for me when I had one installed
  6. Best place to go is euro car parts or probably gsf if I remember right the car was a 2.0 pinto on carbs?
  7. Aim dashboards are probably the best around
  8. If you put a electric fuel pump in do you not need to run a regulator so the pressure is correct?
  9. I’ve booked
  10. Who else fancy’s a weekender it’s always a good laugh
  11. I’ve booked on hopefully I can make it
  12. DeanRudkin
    Engine Swap.
    Depends what your end goal is power wise
  13. Area run or go karting or something like that I personally didn’t get in until around 7:30 last night so had no chance of getting there
  14. Can we get to the show on the Friday or is it Saturday entrance only for camping
  15. I did a budget turbo build to start with and got 240 bhp so it’s really easy and achievable and a hell of a lot cheaper than duratec
  16. Is anyone Interested in a run up to gbs for their event from Leicester and surrounding areas?
  17. I’ve done pretty much the same build as you appart from I’m using the zetec head in my 2b turbo so any questions drop me a message
  18. Antony godden had a set for sale I’m sure he did
  19. You’ll want something like a megajolt ecu to run bike carbs personally if you want to future proof your car I would get a mega squirt then you can go fuel injection for more reliability etc
  20. DeanRudkin
    2L Zetec
    Just make sure you get a blacktop over the silver top in my opinion
  21. Hi mate I’m a fellow Leicester Robin Hood owner I find autosol is the best and to keep on top of it is glass cleaner I do mine once a year usually
  22. DeanRudkin
    2L Zetec
    Would be worth looking at what parts you need before you go buying them as only certain makers of parts only will fit some cars
  23. Good luck with that I had a zetec sump from there probably one of the most basic/ budget things going never sealed up right and just caused me headaches and still took ages to turn up I definitely wouldn’t bother with them again I took it off and went for a Neil dunne one instead far superior quality
  24. Pulse signs and graphics Coalville will be a good shout
