1,714 -
19
Posts posted by jaimo
Also where the ticking noise cumming from
Tap starter then try start
Or put car in gear handbrake off and rock car forward and back try start then
How have people connected the throttle cable to pedels and the carbs i know solderless nipples but actualy how it done any pics would be great also what donewat pedal end got a conversion cable so got all fittings i think just cant seem to work out how to attach at both end
Thamks
Keith the carbs came with megajolt as a setup so hopefully will be bit better when that fitted then will tune them to that well thats the plan
Need to get hold of a balancer although to be fair they dont look that far apart looking at the diaphram lift
Got to change float needle oring as leaking slightly on long idle into bowl and breather on number 1
Thats me out then chris
Already done 50 miles last week
Petrol about 25mpg
oil about 1/4 litre used
The engine runs great now accuspark plugs were just nothing firing motor up ngk in and fires brilliant just a bit of oil on overun going to do full 2.1 rebuild after stoneleigh as if i do the build myself start to finish completly from scratch then i will know it all good
The carb is worn as it has been since got it the person i got it off said it wudnt get aboue 60mph without struggle and cudnt get it tuned right but as i didnt have a working one at all at least it got car moving tryed stu new carb and drives and goes alot better and doesnt over fuel like mine
I have had the bike carbs and megajolt over 2 year just waiting for garage built to fit so now is time instead of wasting money on carb
I appreciate the coments and advice and i am finaly listening do things properly 1st time dont cut corners and do it once just havnt had the time,money or health till now
Already got it all mick just got to fit it my weber and dizzy worn so makes sense
Yes ford sensor
What gap is needed between trigger wheel and sensor
Heard numerous measurements
Thanks
Bit happier as might be right thinking head either crack or guides as took plugs out and number 3 pot same as before looking through plug hole there a pool of oil on top in centre of piston so belieue it to be dripped dowm into chamber from above so hopefully new head will sort theres too much to of dripped off plug anyone else ever seen that
I know you werent matter just abit peeved at minute
Got to do it properly now i think going for a drive first and get head off marcus
Thanks dan engine build is fine
Just realising taking short cuts due to work. Tiling kitchen. Revamping my bathroom. Complete ripout and refit of mums bathroom. Disabled kid wanting me all time etc just hard
Sometimes have to learn that taking someones word something is good doesnt mean it is
Too trusting i guess
Well got up to temp and guess what blue smoke on overun
Maybe time for 2.1 full rebuild or zetec
Shame as sounds lovely also tested compression on pot 1 was only 70-75 psi
Going to try head off marcus to make sure failing that
Anyone got a good pinto for sale need to make stoneleigh
I cannot say in a kit keith
But have drove a escort zetec with a 5.5kg flywheel and once used to it spinning up quicker and slow down faster definatly better feels alot more responsive
As bob says in a car may have to blip throttle prob wont need to in zero as car alot lighter
But should only need to do that with slow gear change
Definatly worth it
Oh yeah
Well just went to try and it started first flick of key
While running
Popping and spitting a bit
Bit of black smoke
Lumpy
So now just wanting a good tune up and run
Yeah running abit lumpy but not took out yet
Now do i risk bike carbs and megajolt before or after stoneleigh
I hear u all sigh
Thanks for all help guys
Its running wants tune up but its runnin
and no smoke ok bit of black but mixture causing that and will sort but no oil burning at minute
Tryed everything then remembered what mick said about plugs replaced with standard plugs and it fired up
They were sparking but obviously not rite
thanks again guys
Engine Won't Turn Over
in Engine
Definatly not getting enough power or earth or stuck the rocking or tapping may sort it
