207 -
7
Posts posted by max
thanks for your reply's have booked a airbnb near for the week end, wife told me what i could do if i made her sleep in a tent in a field
hi thinking of going to the show never been before so my question's are is it worth going for the 2 days , thinking of b&b someware near not bothering with the night entertainment, or can you see everything in one day without rushing, anything i have missed ?
22 hours ago, nelmo said:
I'm just doing a repair at the moment - I used the GBS screws when I first built the screen and they were fine. I recall them being almost triangular and I assumed s/steel.
Will rivets work if you're not going all the way through the frame?
don't know mine has a small gap between the edge of screen and frame
i used pop rivets on mine as had the same problem as you with s/tapping screws'
hi have just comeback from 4days holiday to South Yorkshire and noticed that i have have pinking on acceleration eg up hills the timing was checked late last year do think it is the std petrol would running super be better or add a octane booster in with the fuel be better ?
16 hours ago, Brian P said:
We're sorry to see our Robin Hood 2B go, but we're just not getting the use out of it that it deserves. Great fun to drive, of course, and a real head-turner.
Robin Hood 2B Wishbone, SVA'd 2009 - £4,500 ovno
2Ltr Pinto, 5 Speed Type 9 Gearbox
Oxford Blue GRP and Mirror finished Stainless Steel
Mild Steel Chassis
1741 Miles
MOT until April 2022
Correctly Registered as a ‘Robin Hood – rebuilt – assembled from parts some or aal of which were not new’. See description below for new parts used. With correct age-related number plate.
Exterior
Wide front wheel arches to accommodate 205 tyres
Super-spec all GRP rear arches
Fixed scuttle with DZUS fastened separate nose and bonnet
Full windscreen, mini wiper system with chrome wipers and arms
Suzuki GSXR mirrors
15" MSW by OZ alloy wheels with Bridgestone Turanza 195/50 R15 82V tyres.
5 3/4" Halogen headlight in chrome holders.
Vinyl wrapped, Aluminium lockable boot cover.
Chassis integrated roll hoop (Gloss Black)
Interior
MGF Full leather seats (both on runners)
Sabelt 4 point harnesses
Smiths chrome bezeled gauges, Speedometer, Rev counter, Volt, Temp, & Fuel gauge. An oil pressure gauge is also fitted but not connected.
Individual dash warning lights
11" Mountney steering whee
Short shift gear lever
Mini heater control
40ltr Stainless Steel Fuel Tank
Carpet Lined Boot with decent capacity
Engine
2ltr Pinto, 205 Block (the best engine to bore out to 2.1Ltrs).
4 into 1 Fully Chromed Manifold, Exhaust heat wrapped and sprayed silver
Custom Chrome ‘Chromozone’ re-packable Silencer
Silicone HT Leads
ITG Air Filter
Samco High Performance Water Hoses with Stainless Steel Inserts
Shortened sump
Adjustable automatic fan switch
When constructed the following items were fitted and, obviously, have had little use:
Engine
New Water Pump
New Alternator
New Cambelt
New Clutch
Brakes & Suspension
New Front Brake Calipers, Disks & Pads
Reconditioned Rear drums with new Shoes and Cylinders
New Master cylinder
Stainless Steel Braided Flexi Brake Hoses x4
Adjustable Coil-over Shock Absorbers x4
2.4 Lock to Lock Steering Rack
Where are you please
sorted now new one on way
4 minutes ago, sylvia.fry2 said:
Don't compromise safety --- but new !!!
iam trying to but new
1 hour ago, max said:
hi can anyone point me in right direction as too what master cylinder was used on 1997 mk2 is it cortina or Sierra as mine has just started leaking in to servo, thanks in advance
think i have got the part numbers now anyone got one for sale let me know please
hi how do you tell if you have a low or high compression head on a 2l pinto please
hi what do you guys do about keeping your ticket safe from the parking machine in car parks eg someone walking off with it ? and getting done for not displaying a ticket
thanks for your reply's, will look at doing something like that
hi just got a roof and doors second hand, what do you guys use under the roof from the top of window screen to roll bar do you use fabric strap or a metal one that takes away the strain on top of window screen ?
On 5/18/2021 at 2:31 PM, geoff shep said:
Responding to Shaun in the wanted ads, I dug out some hoods that I had acquired at some stage. The question, is what are they from? Did they ever come pre-fitted with fasteners at some stage? They are better quality than the ones from my old S7 which were supplied unadulterated, but I have no real idea what they would fit.
would you be interested in sell the hood ?
have you checked the earth lead has a clean connection & check the volt reading on new battery if all ok you could have a faulty new starter
yes we would like to go on the sunday
insert two flat blade screwdrivers and then use a bar between the 2 screwdrivers to undo the bolt
now sold
tune up
in Engine
yes did try but they only do that new fanged things, think they call them E C U, you have to plug in a" lap dancer" or something like that
