123 -
Everything posted by Spannerman
Hi Paul I got some Polyurethane Bushes for the rear of my 2b, A lot cheaper than those available at the shows. Very helpful & friendly “if they did not make what I want, Might be able to match, mod, etc other product to fit" I was asking about bushes for coil over. I went to the factory to pick up the above Spectra dynamics ltd Unit C5-C8 Ffordd Derwen Ind Est Rhyl LL18 2YR Sorry no Phone No, but Web site here http://www.deflex.co.uk/ Cheers Kevin PS If you go in Hood mind the SPEED humps
Hi Duncan Do you have a thermostat housing off one of those engines going spare, if so I will be at Stafford on Sat, if you could bring it with you that would be great. Cheers Kevin
Hi Check them out here http://www.toyo.co.uk/ Cheers Kevin
Hello Bill, awake are we. Thats not very nice, Have you ever had to ask twice!!!! I think Not. I will see you at Stafford, In a Robin Hood, at last, Are you still looking over the top of the screen? Cheers Kevin PS I have not seen your name on the email list for Wales, Whats up to much snoring for you, (one of the main offenders me thinks) poor Jim relegated to the out house.
Yes Steven it will be good to get together again, after the winter. See you Sat Cheers Kevin & the Boss
Hi Steve I am going to Stafford on the Saturday, if you can bring it that will be great. Can you let me know how much, Cheers Kevin Ps did you camp opposite us at Le Mans (2004 & have sat nav in Landrover)
Hi all Has anyboby got a stainless silencer for a 2b, you no longer require New or used Cheers Kevin
Hi Rob Just had an MOT on my 2b (Pinto) yesterday, the first time without a servo, Passed no problem Figures were Fronts 300 rears (drums) 275 Hand brake 240 Hope this info helps, Servo not needed, can still lock all 4 wheels. Cheers Kevin
Hi Alan Looks good to me, large too. A poss tip cut a hole for access to the top shock bolt, before you put the top on, use a rubber blanking gromit. I struggled (bolt going the wrong way) when I had to change the shocks to coil overs. Cheer Kevin ps Bill whats Joey up to in that boot
Hi Check out the Northwest site Here http://nw.rhocar.org/sump.htm Cheers Kevin
Hi All Some time ago there was a program on Channel 4? on building a Cobra kit. Did anybody tape it, if so any chance of a copy please. Cheers Kevin Ps email Klp56@tiscali.co.uk
Hi Lee Its not that I wish to get my hands dirty, but I do need to check it over before winter, ill keep checking ebay. Cheers all Kevin
Hi all Just bought a Mazda MX-6 not for a donor, but for my (wife says our or her) road car. Has anybody got a workshop manual, or I believe there is a CD with all the Haynes manuals on? Cheers Kevin
Hi Dave Gayle and I plan to go friday lunch from Runcorn if you want to meet PM me Cheers Kevin
Hi Derek Just a thought is it a fill panel for the fuel filler neck? Cheers Kevin
Hi Bob If you still have the Steering wheel and boss ill have it for a £10 and ill have the fly wheel and clutch of your hands please Cheers Kevin PS Can you please take them to Harrogate for me Iam goning Fri,Sat,Sun Ive also PMd you.
The Friar I worked for Rover for some years if you wish to ring me and discus the problem in more detail send me a PM and I will get back to you. Cheers Kevin
Jase A small problem with Ford wiring looms was the terminals on the ignition barrel lead heat up and break contact with the main loom. Thus causing difficulties when cranking and starting. Cheers Kevin
The symptoms you described could be caused by an electrical fault, (a breakdown in electrical contact when it gets hot) possible faulty componets - coil, condenser, wiring fault, connectors, etc. "I know that the car needs a correct distributor fitting" - if you had inductive system fitted it could be the amplifier or winding in the distributor. Hope this is of use. Cheers Kevin
I'm not too sure on set up on a Zetec, but if they are hydraulic tappets it could be one of these causing the tapping problem, and I would suspect that thinner oil would not help the situation. Hope this is of some help. Cheers Kevin
Exxxxxxcuse me Bill!!!! I have never yet had a complaint about me ever snoring, unlike some, in Wales, Bill!!!! Blaming Joey. Andy - surely the cholates should be for Sue!!??? See you all Friday. Cheers Kevin & Gayle
We're hoping to arrive as early as possible on Friday evening through to Sunday. Not been to Newark before - where's the nearest pub Bill? Jawald - I presume its James, we spotted one flaw in your packing - not enough wine!!! Anyone seen the weather forcast yet? hope it holds out fine for us. Cheers Kevin & Gayle
Hi Simonb 2b plus with recaros handbrake top of tunnel between seats Pluses - good arm rest ,easy to reach & a grab handle for getting in & out Not so goods ( my seat are bolted direct to floor no runners) Passeger get elbowed when appling,(wife looks like a Panda) not much leaverage as arm is high, sometimes difficult on hill starts (Fly off being worked on) Hope these point may help as its not till its finished that you can fully apprase after lots of hard work to you find its Cra******p Can do pics if req Cheers Kevin
