richard mackay
92 -
Posts posted by richard mackay
Anybody out there familiar with Cbr 600 carbs that can tell me why I have
fuel pouring out of hoses from tee pieces at top of carbs.
Richard
Thanks for your help gents. i won't get back to the car till the week end as i work away
from home but i'll let you know how things go
cheers
Richard
The Name of the alternator i have is an ATR seal Supplied by GBS. its the type 1 connections
according to your diagram Nigel plus the big wire which is not showen
Richard
When the ignition is on it should only be the big wire that's connected on this alternator with
a ring connector and nut that is live and the two small wires (ignition wire & dash light)are live
only when the engine is running.Well i seem to have the small ignition wire live with the ignition
switched on and not running.I wonder if that's why the alternator got hot.I'm probably not explaining
this very well but what do you all think now.
Richard.
Could i have the two small wires on wrong way round do you think.The battery drained
very quickly
Richard
Decided to see if my zetec blacktop would would turn over for the first time.
After a few turn and fiddling about i noticed the alternator was quite hot
which made me think what have i done.Its a new ATR seal alternator.
Richard
Cheers guys,i'll give danst a phone cause thats where i got carbs manifold etc
I've just fitted a set of cbr 600 carbs on my 2.0 black top.My.question is,
what size of jets will be fitted as they are right now and what size do i need
for a standard engine.
If you want to spend a bit of money or get some advice on your type9.
First Motion Transmissions are the people to speak to
To anyone who has'nt asembled their gbs pedal box yet be careful to check
that the short pieces of tubing welded to each pedal where the plastic bushes
are fitted may not be properly round due to the heat of the weld pulling them out of shape.
This makes it very hard to get the bushes to fit correctly.
I have a blacksmith friend who is going to reem them for me.
Richard.
Thanks for all the info gentlemen.I'll let you know how it
goes.It may be a while though lol
Am i right in saying that the position of the brake servo and resivoir could be a problem
Simon, any chance of telling me what changes you had to make.I'm asuming you had
a pinto in there before
Has anyone fitted a zetek in an s7 mk1,2 or 3
thanks gents will give things a good check over
please please can anyone tell me why my series 2,2ltr pinto powerd car conks out after half an hour
on the road. turns over like the battery is flat then starts normally after 15 mins sitting.
I'm pretty sure its electrical and have heard a faulty coil can cause this.
Richard
Question for you folks. After driving about 20 miles engine starts misfiring and cuts out,when i try to restart its like
the battery is flat turning over very slow. After waiting for 15,20mins engine fires up and runs perfect.Drive another
20 miles same again.I run a series 2 with a 2ltr pinto on a 32/36 carb. Similar thing happen to me about 30 years ago
with a mk2 escort. That time it was caused by the coil heating up. The coil felt quite warm in the hood but theres a lot of
heat under the bonnet as i'm sure you'll know.Any ideas?
Richard
Cbr 600 Carbs
in Engine
Could be the pump. I know that bike carbs only need 2.5 psi my electric pump is an
of the shelf pump I had fuelling a 2ltr pinto. It may be a bit to high eh
Richard
