2,346 -
8
Posts posted by Dave R
seen him for the last couple of years
first time he had a right bad mood on the day we saw him and he kicked 3 bells out of one of the doors in the enclosure :gdit:
:boohoo: ouch
ok will see what i can get easily
dave send me a pm with your address please
printed out ready to be put on his desk in the mornin before he gets there
i got an engineeers vernier protractor with a spirit level bubble in it
i was gonna go by that for a first attempt
i know my garage floor is somewhere near level
then hold it on the hub/wheel face and see what angle i get
vertical seems to be with the shaft pushed hard into the top slot on mine, so guess thats where i will start
big enuff aint it!
here it is
sorry only a fag box sketch . was never any good with autocad!
nothing too critcal the main od is just a tad under the diameter of the existing mc phearson bumpstops and the taper just to make sure it dont hit the spring
the length looks about right for mine with 15inch alloys but may need adjusting for those with 14's. if anything i have gone to long for mine but its hard to guess how far the existing bumpstop wil squash
the hole is 20mm to suit the chrome shaft, mine is reamed but only cos i found a suitable reamer before i found the drill
on another note dan, what have you got the camber set to ? i was gonna guess at dead upright but yours seems to handle so wonder what yours is set to ?
will do a sketch of what i got with a few sizes on tomorow
someone else pm'ed me for the same sort of thing but i have lost his email so dunno who it was!
i have used all the nylon i had making these but wouldnt be an expensive thing to get them made
i am also fairly hard on my tin-top so guess you better go for it if we geta dry day again this year!
do you mind if you have a current output or a voltage output from this sensor ?
may have one that you can have to less that rs prices!
its voltage and was ordered in error so is unused
will sort it out later to see what range it is but i am sure its in the right sort or range you need
he's my extra spacer for curing the bump stop problem
not as clear in the picture as i first thought. i left the spring off so you can see it but havent slotted the pillar back in at the top
Dan ....... have you got a grease mark on your shaft. "oeeerr missus" that shows how far the suspension travels in normal road use ?
i think the spacers if anything are too long at the moment but its hard to guess how much the bumpstop will compress
rekon i have sorted the bumpstop idea
will post a picture tonight if i remember
basically
(draws deep breath)
the front 2 cylinders hold nitrogen and are coupled via a manifold to the 4 rear cylinders that contain liquid nos
from the bottom of the nos tanks is a pipe to each rocket tube via a throttle/solenoid assembly
in the rocket tubes there is a cardboard tube(similar to a carpet tube) and at the hot end a carbon nozzle
at the cold??? end there is a firework sort of flare that makes the inital heat to split the nos into nitrogen and oxygen
there is also a diesel glow plug heater to light the firework
so far that car has only idled its motors but the technology is sound
and fine as long as its not me expected to drive it
http://www.eurodragster.com/news/news0904.asp
scrol down to 26th of sept
http://news.bbc.co.uk/1/hi/in_pictures/3880579.stm
video clip in that one
but what i didnt say is that apart from the nos it only burns cardboard
was good to meet you for the first time too
i got the original 2b tapes somewhere from the first batch
doubt they are any different but the same offer stands as terrys
the split type not the wrap around
25 mm diameter
from rs over 40 quid a bag with the vat
they do a tool to put it on with but it is posible without
2 packs 10 quid each plus postage
link to the stuff on the rs site
part number 210-8594
http://rswww.com/cgi-bin/bv/search/SearchD...chText=210-8594
i am sure i had to shorten the gearbox mounting bit of angle iron on mine
mind you was a long long time ago!
should be plently of room on the sump as when i shortened mine i exteneded mine into the shallow part, making it deeper at that end
dave
you mean to say that i am the only one with a garage like that ?
must admit its tidier than mine though
you will need 2 extra ones to follow the rear suspension down to the rear hubs
you will eaither need a friendly motor factors or a pipe flaring tool for the end of these
where are you ? i have one, but maybe someone is closer?
Lead Substitute
in Engine
no just take with a little cream and sugar!
