Robin Hood Lightweight Support?
Guest diyer
Steve, take those pics, and any you have of the inside to the SVA with you, they may want to see how its mounted too.
otherwise they could ask you to prove the mounting inside is strong enough for its use.
Only saying as a precaution, looks okay from pics, but when trimmed and finished it would be hard to see whats underneath.
HTH
mitch
Just finished dvd 2
for sva I've used locknuts on all the 6mm bolts that hold the tunnel sides to the floor and those around the engine bay / front suspension and a trim around the rear.
not sure on handbrake placement ,worried cables would get caught in prop on the top?
Just a thought about tunnel top mounting on the Lightweight.
If it's the aluminium one you might want a strengthening plate. You can tunnel top mount on a 2B easily because the chassis centre members are right there and the handbrake can be bolted to it easily. But on the folded chassis you ought to consider whether or not that particular place is going to be strong enough.
Same with mounting it on the passenger side tunnel wall. I would expect an examiner to look for bracing of some sort inside the tunnel that passes the braking force to the chassis. If the handbrake flaps about it'll surely fail.
.... for sva I've used locknuts on all the 6mm bolts that hold the tunnel sides to the floor and those around the engine bay / front suspension and a trim around the rear.....
Do you have to???? I've just replaced the pops with nuts, washers and phillips head screws only. :unsure: :unsure:
You don’t have to use locknuts (nylock or similar) BUT there must be a locking method either a spring washer or a second nut locked against the first also all nuts must have threads of the bolt passing right through them plus something like 3 threads showing through. That goes for all nuts and bolts on the car except the wheel nuts.
Guest Petemate
Absolutely right re taking pics. I had a load of mine, namely seat belt inner mounts etc. The inspector was pleased to be able to thumb through the folder and see haw various brackets etc were fitted, especially those under the trim.
Every little helps.... (sorry Tesco..)
Do ALL bolts used on the car need to be locked? Does it not matter what the purpose of the bolt is?
So once again does this mean RH supply the wrong parts with the kit?????
thanks
Simon
Well not exactly they just don’t supply enough of anything. OK so the bits they do supply are not only not enough but are C&*P :gdit:
The best bet is to throw away all RHSC supplied fasteners (nuts, bolts, rivets, bonnet over centre catches etc) and start again with decent quality items it may sound a bit of a waste but it is worth it in the end.
To be on the safe side yes. I caln't think of any that don't need to be.
