i wonder if anyone can help with this...
i noticed that one of my lights on full beam isnt as bright as the other one. side lights are fine, but main beam one is half or perhaps only a third as bright. the bulbs on, but not very much.
anyone got any ideas? it cant be the bulb can it?
cheers
paul
cheers
paul
I would suspect a bad earth or a bad connection somewhere down the line. Try the earth first.
Hi Paul
Try the earth, usually the cause.
HTHs
Ian J
Great minds, Chris !!!
Or do you just type quicker than me !!!!!!!
Ian J
Ian J
Only by a fraction Ian I was gob smacked to hit the "add reply" button and see your post after mine it must have been milliseconds
Best just hope that we are both right now then. :D :friends:
Ian J
Guest allenr03
Perhaps it didn't pay attention at school.
The other common fault is to mix up the wires at the bulb so you have one filament on for dip and two filaments in series on for main. Look carefully into the bulb that goes dim to see.
