What Dif Is This?
Guest Logix_00
Guest Logix_00
While working on the back brum break, I realised that as I don't have a lot of history about my car I don't actually know what dif I've got at the back. The donor engine so assuming running gear as well is from and old Y reg Ford Sierra. I've attached the photo of what it looks like (dunno if that will help) and the number I think that was embossed on it is "83BG4033-AE" Thanks
Guest Spencer Griffiths
Copied from the Locost Builders site, diff ratios:
Diff Codes ( Ford Sierra Diff codes, Differential Codes, Diff Numbers, Sierra Diff )
Ford axle codes
A=3.36 B=3.77 D=3.92 F=3.842 J=4.056 K=3.31 M=3.14 N=4.29 P=3.58 J=3.62 V=3.33 Z=3.59 2=4.27 3=3.62 4=3.82 5=3.26 6=3.12 8=3.56
3,14 CW47-Pin15
3,38 CW44-Pin13
3,62 CW47-Pin13
3,92 CW51-Pin13
3,77 CW49-Pin13 6.5 inch diff
3,38 fitted to 1,6 OHC ECO 5 speed
3,38 fitted to 2,0 OHC HC
3,38 fitted to 2.3 v6 ESTATE
3,14 fitted to 1,6 OHC ECO 4 speed
3,14 fitted to 2.3 v6 SALOON
3.14 fitted to 2.3 Diesel
85GG 4006 DC --- 3.97
85GG 4006 BC --- 3.62
85GG 4006 AC --- 3.38
85GG 4006 FB --- 3.36
87BG 4006 GB --- 3.14
86GG 4006 AAA --- 3.92 LSD
V87BB 4006 BAA --- 3.62 LSD
V87BG 4006 CAA --- 3.38 LSD
85GG 4006 AAA --- 3.36 LSD
Vin plate codes for Diff ratio
Ratio Code
3.14 M
3.36 A
3.38 V
3.62 U
3.64 3
3.92 D
Give it a good clean with some gunk and a wire brush then spary with Halfords Hi temp aluminium spray paint, it will look like new, see my build photos.
Spencer
Jack up one wheel mark top or bottom sidewalk with chalk inside of tyre
Mark prop with chalk,
Rotate wheel one complete turn, count prop rotations.
You may need to be a bit creative with the prop shaft markings and marking the prop bolts will give you 1/4 rotation marks.
It is most likely you have a 3.6, if you have a 3.38 the bike engined boys and the V8's like them 3.14 is very rear
That said I had a 3.38 originally.
If one wheel is static, you need to turn the raised one two turns.
Most common ratios are 3.62 & 3.92.
Use the well tried scientific formula "Just over 3 & 1/2", or "Just under 4" LOL
If its neither of these, a bit more accuracy may be needed
HTH Bob
The number you need to identify it is on a fragile ally tag held by one of the 10 rear plate bolts, usually the one at 11o'clock. You will be lucky if it is still there and readable. The numbers on the castings are useless. If all else fails the ratio is written on the rim of the crown wheel but its a job getting the back plate off while the diff is in the car. And messy.
Ford axle codes
3,14 CW47-Pin15
3,38 CW44-Pin13
3,62 CW47-Pin13
3,92 CW51-Pin13
Ratio Code
3.14 M
3.36 A
3.38 V
3.62 U
3.64 3
3.92 D
Spencer
I too have been gathering diff data, but the "J=4.056" and the "85GG 4006 DC --- 3.97" ratios you quote must be mistyped/misquoted, as surely there is no practical combination of Pinion/Crownwheel teeth to achieve such a ratio ?
Tony
Tony
OK, the attached image shows the data I have been able to reasonably verify, so far.
... from this I have the "85GG 4006 DC" down as a ratio of 3.92, so I suspect a typo crept into that post.
The original data sources have come from a variety of places, about 50% internet (9 known sites), 25% direct experience, 25% Ford manuals.
The only thing I haven't yet fully sorted out is all the different 6.5", or 7", or 7.5" sizes, but working on this.
The diffs I have been unable to reconcile are :-
VIN Axle code "5" often quoted as 3.26
VIN Axle code "F" often quoted as 3.84
VIN Axle code "J" often quoted as 4.056
VIN Axle code "N" often quoted as 4.29
These ratios don't really work out correctly with "viable" crownwheel / pinion teeth combinations.
As a generalised rule manufacturers don't seem to like the sum of the teeth (CW + P) to exceed 65 (expensive machining time I would guess), and the product (CW x P) to be only rarely greater than about 650 ... although there are inevitably odd exceptions.
This is a tradeoff as a large number of teeth means that the power is spread over a bigger contact area between the pinion and crownwheel, which would give extra strength and quieter running, but the teeth themselves are then also thinner for a given diff size which can limit power capability.
If anyone has some more solid data, then please advise.
Tony
