Vauxhall C20xe Redtop In A 2b Who Has One
Guest ickle
Hi Stuart,
Coolman rad is fine in mine, even on track days & LeMans scorchers.
My engine plates are 8mm & not bent yet....you need a short tube spacer behind one bolt cant remember which one.
I made an adjuster from angle with a welded plate each end. Length will depend on your installation.
You're gonna love it!
  • Replies 67
ye i am starting to get excited now .. i have been ordering some engine bling already lol
so do you run without header tank to ?
can you remember if you had a pot or a flat flywheel ??
i have a pot at the mo and not sure if to try and source a flat
thanks again stuart
I will get pics up soon
I now have my welded big wing sump and bellhousing thanks to yurk speed
He recomends throwing away the rubber sump gasket and baffle and using just a cork gasket?
What you guys think?
I have also threaded the back of my head to 1/2" bsp not sure if to cap it or try get a 90 degree bend onto it and put it to the heater box
Regards stuart.
Vauxhall sump gaskets, you've got to love 'em!
I've tried all sorts of combinations and finally got a seal with the double cork set up and baffle plate that is standard on the red top and loads of the modern 'instant gasket' goo.
Block upside down on the engine stand, layer of goo on the bottom of the block, first cork gasket, layer of goo, baffle plate, layer of goo, cork gasket, layer of goo, sump.
Don't forget you'll need slightly shorter bolts to stop them bottoming out if you're not using the alloy sump, and loctite them in, or they'll vibrate loose.
Leave for at least 24 hrs and you'll have a nice dry sump joint.
ok guys hints and tips for mounting i see steve says front to be 6.5" above top chassis rails
but not sure on getting the gearbox/bellhousing straight any help much appreciated
i can see along the tunnel and when straight ish the bellhousing hits the top of tunnel
also should the gearbox / bellhousing be even along the sides of the tunnel ??
thanks again for any help
stuart
I'm pretty certain that I had to raise the top of the tunnel by about 1.5 inches to stop it fouling the bolts.
Also had to move the tunnel side outwards about an inch on the drivers side and cut off a lug that stuck out on that side of my bellhousing, this let the engine and box sit central and straight - still very tight with about a quarter inch between bellhousing and tunnel side
