Guess The Engine
Guest zoomzoom
Guest zoomzoom
The gearbox is very narrow but very long, I think it's a case of making up some engine mounts and finding the best position for the lump.
Also got a spare sump which is pressed steel so I can make a shortened version hopefully.
Then a new propshaft.
  • Replies 30
Guest alfaGTA
Just £175 and it was local...
WOWZER!!!!!!!!!!! That is alot of kit for £175 Marcus.
I thinks its a tall beast so that might mean another hole in your bonnet......
Guest zoomzoom
Yep will have to look into that as it might be more hole than bonnet soon.
Guest zoomzoom
Once it's fitted don't forget to fill up with petrol more often, would hate to see you getting towed off the track yet again with a "Fuel Pump Issue"........ ;)
Ouch!!!!!!!
I think of a witty reply to that later...
Guest zoomzoom
bit of duct tape and the bonnet will be fine, just call it go faster stripes... still wont catch the mev even with a turbo and no bonnet ;) and yes i will make sure the oil stays in well at least till you start catching me then its dump it in front of you time...
Will it be you driving the Mev? if so not worried..........
Might be worried if say you found a angry teenage girl to drive it, might be quicker and do more than 3 laps...... ;)
Guest zoomzoom
Sorry the pics are so small I can email some bigger ones but the owner should be able to help. I remember being surprised how small the gearbox looked
Thanks for that, I will try to contact him and pick his brains
