Superspec Steering Balljoints
Anybody know what the replacement parts are for the balljoints that connect the track-rod ends to the hubs (on the Superspec)?
Mine work, but rubber is perishing, and MOT is coming up.
Thanks,
-steve
A good local parts shop possibly have boots on stock or trawl the bay they are easy to fit ,no disturbing track settings even if you are cack handed no more than an hour for both sides and a cup of tea !! :clapping: mower man
Try these I have used them in the past.
http://www.balljointboots.co.uk/
HTHs
yep i've changed split balljoint boots, the original RH boots perished before even using them so just replaced the boots.
Might be different on your but just in case if you fit new boots be careful with the spring clip as it can have sharp ends and piece the boot! When i did it i put a bit of cardboard under the end bit and lots of grease so it would all slip on easily.
hth
Thanks to all - going for new boots.
-Steve
