I am after a windscreen glass for my 2B after original one shattered today. If you have one can you please confirm cost and location to allow collection.
Many thanks
Robbie
Template and local glass co is the way to go but you need 4mm laminated if you can get it otherwise any thicker is very difficult to get into the frame.
I've had a couple of screens cut at a local glaziers in 6mm laminate. They don't fit with the standard black screen rubber, so I just use silicon. cost is usually £30-£50 (Mine's more expensive due to being bigger) HTH Nick
Agree with Nicko, I had a laminate screen cut (6mm laminate) cost £35, used black silicon to seal in the frame.
If you want the original toughened screen, i've got one in the garage you can have.
Drop me a PM if you want it
Thanks for all the replies. It would appear that a laminate replacement is the preferred option.
Al, if you have an original one going spare how much do you want for it? At least I can use this as a template. Please sent me a PM.
Thanks again.
Robbie
Guest iank
Like Nick and Al, my screen is 6mm laminate.
An alternative to silicon, I got some 1mm rubber strip off of ebay for about a fiver. Fits a treat, with the help of a little vasoline, and allows you to dismantle easily.
Ian
Thanks to Al Milton replacement glass collected and ready to be installed!
Hope that the bucket and spade run went well.
Thanks again
Robbie
Personaly would only use laminated ,I 've lost one eye to toughend screen don't have much option ,like others local glass co 6 mm lam ,silicone 40£ ish mowerman :clapping:
