Al Milton
Al Milton last won the day on May 31 2016
Al Milton had the most liked content!
2 Followers
    Super Spec
    Alan Milton
Contact Methods
  • Website URL
    http://
    Ramsgate, Kent
19,467 profile views
Al Milton's Achievements
Wheely good builder!
Wheely good builder! (4/6)
291
  1. Rest in Peace Dad, he sure knew how to build a great car or 2! Condolences to all the family
  2. Hi Lloyd, Hello, I'm in Ramsgate with a Superspec. If you want to have a nosy at a completed car, take some pics etc, then drop me a pm and we'll get something arranged. Cheers Al
  3. Apologies for the lateness Bob, been away on hols. A belated Happy Birthday Bob, hope you had a good day. Cheers Al
  4. If you go down the calibration route, to ensure it is done accurately you'd have to calibrate the whole loop, sensor, cable & gauge. It's no good doing one or the other (or both) as you may have a potential unknown voltage drop between the two in your loom, causing errors. If you have standalone gauge, couldn't you do a comparison at varying rpm (almost like spot calibrations) via a temporary 'T' piece, this will give you a known offset to apply. Simpler than trying to find a suitable resistor or full calibration (& cheaper)
  5. If the ends have a sharp end, I doubt if the lines will need replacing. Just remove and trim up, but trim with a rotary cutter (the type use for cutting copper pipe), then replace into the connector. GBS may have the pipe in stock if you really want to replace it
  6. Just a thought if you are using the standard supplied tank that has the red & white (flow & return) hoses. If you have the supplied red/yellow 'plastic' fuel hoses that push into the connectors, are they: A: connected to the correct ports? (from memory I think the red is the supply) B: have the ends of the hoses been cut with either pliers or side cutters? This may have left a sharp point on the hose that has damaged the seal within the push fit connector C: again from memory, but I think there may be 2 seals (o rings) within the connectors. Have the hoses been checked that they are as far into the connector as possible? It might be worth checking the hose ends and re-seating, but lubricate the ends of the hose with a little fuel before inserting into the connector
  7. Looks absolutely stunning Bob, what a lovely new toy. Bob T is referring to motion sickness tablets
  8. As Al says, the column is Mondeo, a Mk 1 I think. I considered a removable wheel, but the hub is a 2 part affair, with 1 part permanently fixed to the column with the removable part fixed to the wheel obviously. This does make the wheel sit closer to you as the whole affair is deeper than the Mountney hub originally supplied. Have you considered a flat bottom..............steering wheel as these can be supplied in a slightly smaller diameter which increases leg/belly room
  9. Deano, have you tried re-calibrating your ETB speedo after the re-wire? There are a few methods, but the one I used was to drive for 1 mile at a constant speed. There are instructions on the ETB website if you have lost the instructions
  10. Thanks Bob(s) & Mo. Just chilling out with a glass of cold fizzy water Perish the thought of long trousers.........
  11. Wow, that would be one hell of a snowman! 5 car crash at the bottom of our road Wednesday morning, one pedestrian hit by a car. Only then did the council grit the road
  12. Many happy returns Bob, lemon tonic water..... really? Have a glass or 2 of red, they'll be better with the steaks which i'd happily offer to cook for you. If I could get out of my road of course. Hope you had a great day young sir! Take care Al & Lana
  13. Pack arrived today, only got 1 sticker, but then again I've only got 1 windscreen! Nice striking colour though
  14. Hi All, A group of us did this a couple of years ago and had a good day out eventually ending up by the seaside in Ramsgate. Unfortunately I cannot make it this year due to a prior engagement, but if anyone fancies a run out with up to 400 cars finally showing up, then here's the link with all required info. http://rommcc.org.uk/bucket%20and%20spade%20run.html Fortunately this year you won't have to dodge the cow poo as the set off point is a car park at a garden centre Cheers Al
  15. https://www.ebay.co.uk/ Whoo Hooo, thanks Richy!! Link above is a test but now working Thanks again Richy
