Morning all
Been having loads of problems with my Sierra master cylinder and now know its knackered. Been looking about and you can use some Fiat and also Mk 1 Fiesta cylinders.
Has anyone got any other ideas about what makes you can use?
Graham
Guest sandy77uk
I used the escort Mk 5 master cyclinder on my Zero (has 4 outlets so each corner is on a seperate brake line)
KA m/c with-out servo works fine on our 2b fitted with all standard Sierra braking system. Still possible to lock the wheels if pressed too hard.
I have a ford ka m/c going spare but I'm a bit of a distance from you (I'm near nottingham).
I could bring it to the next s.yorks meet if you was going to be there?
Guest alfaGTA
Is the ka a direct replacement for the sierra one? i.e. do the mounting holes line up?
From failing memory----- The holes are the same but at a different angle (10 past 8 instead of 5 past 7 I THINK) the flange angle is also different by about 15 degrees -- also the front/rear connections are reversed (they were on my model -- may differ on others) don't get easy does it??
